If your 14" is a woodcutting bandsaw,you will have to slow it down with pulleys.Metal cutting bandsaws run at a speed of 100-200 fpm,woodcutter at 1500-3000 fpm.Friction cutting metal on a wood saw is an option,but you would need to get the speed up to 5000fpm +,and I am not sure what type of blade to use in that application.For regular metal cutting,a 14 to 18 tooth BI METAL blade (depending on the thickness of your stock)will work fine.
MIKE
