I'm looking at a Grizzly G0621X. The bottom end of the speed range is probably a bit fast for a knife shop but being indirect drive, I think a change of pulleys could fix that. Importantly, the selection for 108" blades doesn't seem as wide as I would hope.
I was thinking that bi-metal, raker set variable pitch blades would be a good choice for cutting blade stock and profiling. However, I'm having trouble finding fine enough tooth pitch or narrow enough blades for what I think I would need.
As I mostly work with 5160 in 1/4" and 1084 down to 1/8" for flat stock I am under the impression I should be going with 20-24 at the coarsest but might want narower than 1/2" for cutting radiuses.
What I hope to learn is 1) am I even on-base here, and 2) do I have any options? Even mscdirect only has pitch down to 14-18 and width down to 1/2" in Lenox blades. I'm pleased to keep researching for myself but I could use some guidance.
