- Oct 18, 2001
There should be 2 adjustments on the top wheel. I would guess that your top wheel is set out "too far" and causing the blade to slip off (regardless of the pitch of the upper wheel). I'd try to find a way to get it sit back in the machine more.
cmd - glad to see the problem fixed! :thumbup:
I too have noticed that if I tighten the blade as tight as I can get it with two hands and a piece of wood as a lever....I can bear down as hard as I want on my saw without it jumping off. I cut hard and fast on it, both thick and thin stock...works great. (14-18 tpi, 200 rpm, 1/2" wide blade - yes, I cut straight lines only - and I use fluid with it too)
