Angle grinders work pretty well. You can mess you design up if you try to go too fast, but with good quality discs and a little patience, you can do just fine. The ground areas will need clean up, but that is par for the course. I have used one for a while because I never had enough patience for hacksaws, but YMMV.
I drill out the large areas then run the hacksaw thru the little connectors.
