Bark River Northstar, first impressions.
.... who is it you think bought him?
Generally it is in regard to the people who make the knives I describe with positive characteristics and/or refer to often as benchmarks such as the Mora 2000, Bruks Wildlife, Ratweiler, Johnson utility, etc. . It is an example of when you can't deal with the arguement you attempt to destroy the reputation of the speaker. Of course if the guy speaking was totally without substance it should be kind of obvious that the arguement should therefore be easily refuted on a factual/logical basis.
You could take thick stock and hollow grind the hell out of it to do that, while leaving a heavy spine for impacting and wedging, but that doesn't make any sense. Also, you can convex grind and get yourself an edge, but it wouldn't be all that fine comparatively if you're working with 5/16" stock or something.
In general I would not tend to prefer either of those types of grinds but there are uses for them. David Boye for example had knives which were close to 3/8" at the spine but 0.005" at the edge where you had a combination of very high shallow cutting ability and very high strength, dive knives. Even his hunters were ~1/4" at the spine because they mainly did shallow cutting (or deep cutting on non-binding media) and the wide and well rounded spine was a nice ergonomic aid. I also think the fact they were cast had something to do with it.
A knife should cut well, but that means it probably shouldn't 'split' so well as defined here-unless you like cracking all your firm vegetables while cutting them.
Yes, in general. There is kind of an interesting point here though, I have done test cutting with really thin blades on carrots/turnips and found that there is a point where if you decrease the thickness further the force goes up because the vegetables have enough elasticity to not crack at all and thus they bind heavily. These are really thin knives, 1/16" with very wide blades so they have really acute angles, ~3 degrees. You can usually compensate for this with use of hollow relief grinds.
...why is your reading comprehension so weak that you did not realize that Cliff never said anything against a BRKT product?
He isn't responding to what I said just his general impression of me, often from what someone has said or past posts I made where I critized a knife/steel, this is fairly common. For example you will note the constant references to "but I don't break knives / chop up concrete" if someone is in disagreement with me and they use that to imply this is why their opinion is different because that is all I do. In fact I have not done either of those things in a long time, the vast majority of work I have done recently has been on blade minimization (what is the least knife I can do something with) and trying to quantify edge retention in a more defination manner. Even when I did really harsh work it was always a minor part of the reviews and in the majority of the times on request from the maker/manufacturer.
And yes, that was my main point about the convex bevel. It isn't the curvature which defines the properties. I have a cutting tool now with a convex bevel which is about 1/8" thick and 25 degrees per side, that is the midpoint tangent angle so the apex bevel is actually much higher. The edge is well sharpened, viewed under magnification straight into the edge it is as well formed as any Spyderco I have seen so it is very sharp. However it in general will not cut well because the angle and thickness is very high and being convex doesn't change that at all.
As a general note, the main reason that posters like LaBella engage in personal attacks is to try to induce the same in responce. The ideal reply is to attack him and better yet the product he is supporting with equal or better vigor, this both destroys your viewpoint as being impartial and ideally also locks the thread so any further critical discussion is prevented. If you are losing a debate and turn it into a fight which causes the debate to be closed then it is highly likely that people will forget about any valid critism and just remember the fight. So in short, try not to return the insults/implications.
-Cliff
ok, gents
without capitalizing and using apostrophes
Cliff-did YOU test THIS Bark River in question?
thanks for the kind words especially being full of shit and unintelligent.
i have been here for some time watching this guy spout off and it was testing from afar that got me. i apologize for getting wound up, but this cliff has had his butt handed to him several times but prominent knifemakers and it is not supporting any one particular brand.
i think he gets money from some to be more "scientific" if you will than to others.
you can call out my type style all you want. I even capitalized Bark River. If you are all so smart why don't you make the knives......
THAT is my point.
oh! and feel free to report my post, omg i hope it doesn't go on my permanent record!
threw a few caps and punctuation marks around to make you all feel better about someone forming your opinions for you
question the messenger is all i am saying
Ron, you're not doing your cause any good. These are personal attacks, not arguments against Cliff's arguments, and against BF policy. You need to stop posting on this thread, or completely change the content and style of your posts.
nobody did, read the first post. Also read the subsequent posts, where Cliff doesn't even discuss Barkies in particular.
no, you're saying more than that, and none of it has bearing on the actual discussion in this thread
Thank you, Mr. Talmadge. You've given us all a wake up call.
And I would like to apologize to Mr. LaBella for the rather hasty comment about him beng full of ****! That was totally uncalled for, and I wish that I could take it back.
Ben
...did YOU test THIS Bark River in question?
I have used many knives which that grind in detail yes, some came that way and others I so ground so yes I am speaking from experience on how the grind performs. HoB sent me the full details on the grind awhile ago.
... If you are all so smart why don't you make the knives......
Mainly because I enjoy using them more than grinding them. That is a extremely weak arguement by the way, would you ignore what a logger has to say about axes because he didn't make any - of course not. Why not degrade knifemakers who don't make the steels they use or why many of them don't even heat treat their knives.
As for me having my butt handed to me, yes, that is why I am here and not in a forum where I moderate. Have them come into an open forum such as rec.knives which is not moderated and see how they handle a debate when they can't moderate the discussion. I can guarantee that it won't take very long before they leave and that their entire side of the arguement will consist of nothing but ad hominen statements with no facts at all to support anything they say because quite simply if there were facts to oppose any point of view I had I would no longer have that point of view.
In regards to getting paid, instead of throwing out vague and general accusations actually be specific and say which knives can not perform as I have described and do so in the forums of the manufacturers of those products and get their reaction to you calling their products as lacking substance and being promoted by pure hype. This calls those manufactuers/makers liers as many of them directly have supported what I have said.
I have always provided extensive references to the performance I have described, including both live demonstrations by the makers and other users, published material properties, and attempted in great detail to cross reference the reviews so as to present a consistent viewpoint. I as well speak in terms of generalities, speaking of geometries for example which are independent of the maker.
I have also been just as hard on the makers who I am friendly with to those that have constantly done nothing but spew personal attacks. I took both Ray Kirk's and Strider's knife to the same use, I subjected Busse's Basic to extreme use when ended in it being the first publically noted gross failure, I have broken many Spyderco's in many ways, etc. . Again, if you see that in a review it looks like I am not doing work to show the weak points of a knife then just request that it be done.
-Cliff
"Cliff-did YOU test THIS Bark River in question?"
No he didn't because I still have it. I guess if he didn't actually test my knife, he can't know what he is talking about?
Anyway, I don't know you have against Cliff and I am not interested in getting clued in.
This Northstar looks like it is going to be a winner. I don't see anything about the blade that I don't like. It is the handle that I wish was a little larger. A small gaurd would be a help as well. The blade is the reason I bought this knife. It is one of the best blade shapes I have seen in a while.
I have Northstar too and it is a great knife. I haven't been around here long but this Stamp guy reminds me of a movie critic. Quick to critize and claim knowledge of everything but for some just can't seem to create the perfect product himself. I think he thinks he is a genius because he has a PhD from an extremely mediocre and obscure university. You just have to laugh at people like this.
Whether you agree with Cliff or not, he certainly makes you think. And, I see nothing wrong with that.
I have two North Stars, and I think they are solid knives -- for me.
"Perfect product"? I doubt that Cliff seeks the unobtainable.
As for The Memorial University of Newfoundland, and its 17,000 students, being "extremely mediocre and obscure," I am sure you would not make such a claim without a reasonable basis. So tell us what that basis is, sir.
Hard to top Harvey Mudd College for obscure. :)
Not so hard.
1) How many people have heard of it?
2) Please cite statistics that place this university among the top in the world?
3) Can't remember the last time I heard of groundbreaking research coming out of The Memorial University of Newfoundland.
Actually, Harvey Mudd is considered one of the top colleges of it's type. Anyone in engineering, academia or an industry that uses talented scientists can tell you that. It's only obscure to those who wouldn't make it there.
Not so hard.
Gee, "not so hard"? I thought the burden was on the person with the affirmative of the proposition. You claimed that Memorial is "extremely mediocre and obscure." That's a harsh judgment on that university. You ought to have some basis for such a claim other than "geneepi" never heard of the place. Tell us about it's low academic rating, the unaccredited programs, the difficulty in placing graduates - you know, proof.
As for the jewel of the Claremont Colleges, if you were really "in the know," you would be aware that Mudders regard HMC's obscurity as a badge of honor - along with its facilty writing the textbooks for MIT and Cal Tech.
But we'll wait for your proof than Memorial University is "extremely medicocre." Will it be a long wait? :)
I have attended some of the best universities in the nation and some of lowest tiered.
Education is what you make of it, and in most cases takes a back seat to common sense anyways.
The my PhD is worth more than your PhD game seems a bit silly to me.
I agree completely, KT.
So let's stop watching the kid twist slowly in the wind as he trys to find something -anything - that would support his defamation of Memorial University. That defamation is just "collateral damage" in an attack on Cliff Stamp.
Memorial is one of the top universities in Canada, a nation that need apologize to no one regarding academic standards. Memorial ranked 5th nationally among Canadian universities with significant research and a wide range of undergrad, graduate, and professional programs in the McLean's survey for 2005, and ranked 1st nationally in universities with 12,500-25,000 students in the Globe and Mail 2005 survey.
Now all this ranking stuff is subject to argument regarding standards used and subjectivity, and Knifetester is correct that "YMMV" regardless of the schools that you attend. But Memorial is emphatically not "medicore" either absolutely or relatively.
And note, by the way, that Cliff does NOT waive his degrees in our faces.
Actually, I have known a number of "Mudders" and I have not heard one of them say that was a badge of honor. One of my best friends at Princeton went there as an undergrad so I do know a bit about it.
Not a long wait. Look up any number of the top rankings on universities, programs, research etc...guess what, you don't see Memorial University on any of them. I have been lucky enough to study and work at some of the best universities in the world. I know what the top universities are and trust me Memorial isn't one of them.
"the unaccredited programs" : Devry has accrediated programs too. Guess its the equal of Harvard.
"along with its facilty writing the textbooks for MIT and Cal Tech" : I think you meant faculty? Now this implies that every textbook used at MIT and Cal-Tech was written by HM "facilty." I hope you have more intelligence than to believe this. I'm sure a few HM authored texbooks have been used at MIT and Cal-tech, but all of them? Now please show me the proof of this. Will it take long?
You should try harder :rolleyes:
Changing the subject are you? I thought Memorial University was not just "medicore" but was "extremely medicore." Only it turns out that it clearly is not.
Didn't say "all," and a bright guy that you are, having attended the best schools, knows the difference between "imply" and "infer." But -- :yawn: -- just another attempt to shift to another topic from "extremely mediocre" Memorial University.
"Memorial is one of the top universities in Canada" : It is classified a a comprehensive univeristy i.e. comparable to a university like Illiniois State University in the US. Now not to knock schools like this but it is well known that the standards for schools like these are simply not the same as top-notch schools. Its beyond easy to get in, the academic standards are low, and there is little relative research coming from these schools. You can get a decent education at most universities but making comparisons at the between these types of schools is ludacris. There you go gramps.
I don't know Stamp personally but from reading a number of his posts he strikes me as the type of person I have dealt with on numerous occasions. They have a PhD from a low level program and they think they know it all when, in fact, they don't. You can find dozens of posts where people are discussing something and he jumps in and basically calls them stupid and proceeds to inform everyone that his view is the only correct one. A typical person who thinks they know it all but in fact don't.
As a very smart man once told me, difference of opinion is what makes ugly women marry and poor land sell. If you like Barks, and they do the job for you, buy 'em. If not, don't. Also, let's not get nuts when someone doesn't have the same outlook as us. I'm not an engineer, and don't have a PhD. I like what I like, and what works for me. Bark Rivers do. Have a great day. Bill
Read what you wrote, "writing the textbooks for MIT and Cal-tech."
You know what you were implying. Writing "the" text books clearly implies all. If you didn't mean all you would have said "some."
Here genius: facility = building or place
faculty = people who write the books
