To answer your question - I believe you should try to get a refund for this knife, or a replacement if not (that you can immediately sell).
That knife, in “A2?”, or really ANY quality steel should not have bent so severely just doing what I’d consider light chopping.
My Siegle has a ~.025” wide bevel, and the thickness behind the edge (so .025” from the edge) is ~.020”. Zero edge deformation after maybe 3-5 hours total chopping various wood (including dry).
If your knife was ground substantially thinner than that, they made it too thin and it’s their fault. If the knife is ground properly for its size, and it rolled like that, then either the HT is bad (likely imho) or the steel is junk (also sadly possible given the history). (Also their fault).
View attachment 1858307View attachment 1858308
