Offered is my minimally used, but near excellent condition Barrel Flashlight M2JN Gen3 in Brass with H17F driver.
Sculpted 3D titanium clip and barrel ring and inner barrel sleeve. All parts interchangeable with other Barrel flashlights - so you can further customize as you please.
Green glow ring in head activates quickly after use.
Uses a rechargeable 16340 battery (included).
Tumbled stonewash brass body is developing some nice patina. There are a few marks to the bezel lip, v small. One superficial scratch that should soon blend in with the rest of the patina.
Includes as shown a nice Mommahanks velcro case.
From the makers site: Barrel Flashlight Co. flashlights are proudly made in USA. Our lights are turned from solid round bar. About 1000 lumens on high depending on LED’s selected Triple LED output with builds with Cree XP-L HI 5K. The “ pill “ that houses the LED’s and driver is machined from solid brass for optimum performance and heat transfer. Light measures 3.5 inches long and just under 1 inch in diameter. Light runs on an Efest high capacity 700mAh 16340 unprotected button top rechargeable IMR battery (included). Light is built with one of the most advanced drivers on the market: the fully programmable H17F with battery monitoring. The H17F comes in a very user friendly set default of moonlight, low, medium, and high. Rear “ clicky “ button cycles light through modes. For the avid flashlight hobbyists , a secret hidden mode can be entered to program the light. Light is water resistant. Light tailstands very well.
FULL image gallery: https://imgur.com/gallery/TtFMBSU
Specs:
89.5 mm length
25.1 mm wide
186 grams (with battery inserted)
Further Details here: https://www.barrelflashlights.com
Asking $OLD elsewhere.
Specs:
89.5 mm length
25.1 mm wide
