Smaller than a poker card but with enough power to recharge your devices a few times! The Baseus M25P 10000mAh power bank is equipped with dual input and dual output - USB-C PD output/input, Lightning input, and USB-A output. Packed with 10000mAh of battery capacity, the M25P is perfect for long journeys and camping. It has a smart chip that automatically stops charging when the battery is fully charged, and therefore protects it from damage. The small size makes it ultra-portable and suitable for almost any purse or pocket.
Product Features:
● Dual input and dual output, can charge two devices at once.
● Built-in power path management, supports charging and discharging at the same time.
● The Type-C Power Delivery port offers fast charging with a max output of 5V/3A.
● The USB port is capable of delivering up to 2.4A of output power for fast charging.
● Intelligent identification of charging device to match suitable current.
● 10000mAh can recharge your devices multiple times.
● The shell is made from high-quality ABS and PC materials.
● Integrated LED display shows in percentage the remaining power.
● Automatic turn off the power after fully charged.
● Safety certification, CE/FCC/RoHS.
● Built-in multiple protections, safe and reliable to use.
● Mini size and lightweight, easy to carry.
Don't let your USB-powered gadgets stay without power while you're on the go, just put the Baseus M25P power bank into your pocket: https://gearvita.com/baseus-m25p-10000mah-mini-pd-power-bank-type-c-charging.html
You may also like:
huawei cp60 wireless charger
xiaomi 20w wireless fast charger
Product Features:
You may also like:
