Basic Frame kit for No Weld Grinder
Feedback: +3 / =0 / -0
Frame Kit for No Weld Grinder - Basic frame in kit form
$350.00
Basic Frame Kit for No Weld Grinder
This is a kit of the basic frame for the No Weld Grinder. This is NOT all you need. It is the basic metal frame only, you will need several more items to make this into a fully functioning grinder. The kit comes with the metal needed for the following:
  • 1 tool arm for a contact wheel
  • The basic frame which includes base tube, uprights, tracking arm and tracking adjustment block
  • 1ea tracking arm handle
  • 2ea 5/8" pillow block bearings
  • 1ea drive shaft with key way slots milled on both end for key (keys not included)
  • 1ea adjustable tool rest with 1 small tool table
  • 4ea 4 bump knobs for tool rest and tool arm positioning
  • 1ea knurled knob for adjusting tracking
  • bolts, nuts, washers, lock washers to assemble basic frame (it comes un-assembled for shipping)
  • an assembly instruction manual with clear pictures and assembly instructions
  • 2ea 1/2" diameter bolts with washers and machinery bushings to mount tracking wheel and contact wheel of your choice (wheels NOT included)
  • spring for tracking arm tension
  • 1ea full set of No Weld Grinder Printed Plans. You can sell this one original set of plans to someone else if you like. (you can NOT sell a copy or copies)
NOTE: These frame kits are made by a co-operative working together to make a living wage located in North Dakota. These frame kits will be drop shipped via UPS from Bathgate North Dakota to your location. The freight charges reflected in this shopping cart will most likely NOT be correct. There may be some additional shipping charges. We are new to this process so please bare with us as we work out the details and gain experience. This kit has some design changes to the No Weld Grinder printed plans to accommodate mass production. I have worked directly with this co-operative and believe these design changes are perfectly acceptable to the basic grinder design. Many changes are in fact improvements over the printed plans design.
You will need to purchase several more items to make this into a functioning grinder.
You will need to purchase additionally:
1ea Drive wheel (we sell these - same as found on the KMG by Beaumont Metal Works)
1ea Tracking wheel (we sell these - same as found on the KMG by Beaumont Metal Works)
1ea Contact wheel of your choice (we sell these - same as found on the KMG by Beaumont Metal Works. We also sell Poly contact wheels at a lower price.)
2ea pulleys of your choice (we recommend either 3step or 4step pully set for 3 or 4 speeds)
1ea motor (we do not sell motors)
1ea drive belt (we recommend the power twist link belt we sell - you need 3 feet, order 3!)
The features of this frame kit are:
Several points are welded. I understand the plans say no welding but this is a production kit. The design accommodates welding very well and this is an improvement. Multiple 4 bump knobs for tooling and tool rest adjustments are included as is a knurled knob for the tracking adjustment. Tabs are welded to the bottom of the base tube for mounting to your stand or bench. All holes are drilled for you! Assembly of this frame will take 20 minutes with 2 wrenches. Most edges have been cleaned up but as always, be careful about sharp burrs. The assembly manual is exceptionally easy to follow with multiple pictures.
What is NOT included:
A flat platen attachment or slack belt attachment. I am working with the co-operative to make these available as an option. We are still working on the details for this. You can always make these very simple attachments yourself by ordering the metal pieces from us. We encourage you to have multiple attachments to extend the versatility of this tool. I have 8 different attachments with different wheels for mine and I use them all.
FAQ's on this frame:
Why do you have this?
I got a lot of requests to build a full grinder for people and also to offer a kit of all the metal parts. This will fill the needs of a lot of people that simply don't want to make the frame or can't locate the metal in their area. I don't have time to make the kits myself or to build full grinders. This was a natural. A group of people working to make a Living Wage by creating their own work in a rural area of North Dakota where jobs are hard to come by.
Why don't you include the wheels?
A lot of guys are making their own or buying the contact wheels else where.
Will you ship international?
Sorry, not at this time. The people making this are not set up for international shipments.
Why don't you include the wheels and knock a bunch off the price? Free would be nice!
I know. This is the best we can do and I already charge the lowest price I can.
I can make this for a lot less than you are charging!
Yes, you can. Probably by $100 to $150 dollars less. I would really encourage to make your entire grinder BUT some guys just don't want to. This is a very good price considering the work and metal that went into the frame kit.
How much is shipping going to cost me?
You can check with UPS for shipping charges at UPS.com. The sending zip code is: 58216. The box size is 20x12x12. The shipping weight is 49 pounds.
How does the shipping charges work again? Your shopping cart wants to charge me $xx and UPS says $xx what will I pay?
You will pay the UPS shipping charges from zip code 58216. We will make any adjustments needed either by charging you more or refunding any overcharge.
How is it packaged?
In a box approximately packed with styrofoam and packing peanuts. I hate packing peanuts too but this is going to require it. The metal frame is in pieces, stacked and shrunk wrapped.
How do I order one?
order it here through the shopping cart and we'll work through it via email or telephone if there any adjustments to shipping.
Why are the plans included?
There are several pages on motor selection and several more pages on abrasives for reference. We will mail those to you separately It's just a darn good read too...
What is the meaning of life?
42
>CLICK HERE TO GO TO USAKNIFEMAKER.COM<
Anyone used one of these?
How have these been working out?
Thanks!
Yep, I made mine a few years ago and have no regrets. I didn't buy the kit, but made mine using Tracy's plans. It works great and after having it, I could never justify buying an expensive grinder. Go for it.
-Mike
Tracy, except for the motor, how much more money will it take to make this funtional considering I buy the extra items you specified?
That depends on what configuration you want and there are dozens of possibilities. You can call me or give me an email at tracy@usakms.com I'll be glad to help you get an idea of the costs.
Sorry, I won't be able to go over all the different cost combination's here.
