basic home tool kit
Nobody uses a saw at home? A 10" hacksaw with a selection of blades will serve you well, and a small crosscut wood saw will come in handy. If you buy a drill don't forget an index of drill bits, and some phillips bits to use it as a screw gun. Allen wrenches are nice to have as well, and what knife knut doesn't need a set of small torx bits?
Get the cordless, not charged? Coffee break, come back after 30 mins and she is ready to go. :D
Get the corded drill. Not plugged in? Get the extension cord. 30-seconds later and she is ready to go. :D
IMHO-
Basic tool kit:
Chapman gun screwdriver kit-the one in the yellow plastic box
Dewalt 12v or 14 v cordless drill
Milwaukee or similar CORDED HAMMER drill
1 framing hammer 20 oz, 1 ball pein at 8-12 oz
12" Channel lock
8" locking pliers(vise grips) w/ wire cutter
10" Crescent wrenchKlein or similar make wire stripping tool
25 w soldering iron
12" hack saw
decent jigsaw, I have a Bosch
3/8" ratchet with full set of metric and standard sockets
Chucks recommendation on extension cords
20' tape measure
2' spirit level
I personally cannot live without a Dremel, but that can come later.
That should cover the basics, I don't think I left anything out.
Best Regards,
STeven Garsson
Gollnick I'm fond of saying, "Four-wheel-drive is just a way to get stuck in a worse spot." The basic principle is that you have to be careful that the tools you have match your skill level. A Sawzall in the hands of the average home owner is just a ticket to a high repair bill.
I think that sawzalls are a great, versatile tool, and not one that takes too much skill to use. They are great for cutting tons of stuff and can take the place of numerous other saws in a pinch. You might be correct in saying that the average homeowner would screw things up, but as long as they know their limits, they should be fine.
I prefer Sawzalls to the other Reciprocating saws personally. +they have a lifetime warranty. I would prefer a sawzall to a jigsaw/scrollsaw, but they are more expensive.
I bought a little B&D jigsaw 6-7 years ago. I have used it nearly to death, but I cannot function without one. I have 4 or 5 other saws, but I have had great luck with a jigsaw.
I saw a "basic tool kit" at Home Depot with simple stuff like hammer, screwdrivers, pliers, etc. They have a 160pc. "Mechanics Tool Set" for $80. It's not really a mechanic's anything...here's the description from the website (www.homedepot.com -"hand tools" on the the drop down menu, shows as a best seller):
This jumbo set includes all the tools you need to complete most projects: 14 hex keys, a hammer, four sets of pliers, 44 pc. screwdriver bit set, 10 combination wrenches, an 8 In. adjustable wrench, utility knife with seven blades, 25 Ft. measuring tape, six screwdrivers (including a multi-position ratcheting screwdriver), 53 pc. socket/ratchet set and carrying case with two trays.
The four sets of pliers are apparently 2 sizes of needlenose, a channel lock, and a Vise Grip.
Here's the pic:
Add a drill and a set of bits and drivers, and you're well-prepped for most of the simpler home repairs.
I have more tools than I want to think about, but the socket set and drill are invaluable. And in spite of having all those tools, around the house I actually use a Leatherman for most of screw driver, plier stuff, unless something bigger or more specialized is needed.
I have to agree with most of these guys about Craftsman HAND tools(their power tools really aren't that great, as mentioned) but the hand tools are, and you'll NEVER need to buy new ones. What I did was buy a cheap Craftsman kit(a big one, but I use the tools alot) they come alot cheaper in these big old blow molded cases. They are the cheaper, lower quality tools in these kits, but at least comparable to anything you'd find at Wally world, and when you break something, you just take it back to a Sears and get the better quality pro tools to replace them. I have never had a Sears employee stop me from taking the pro-level tools as replacement for the cheaper kit tools, so now pretty much the entire kit is pro quality. You'l get on average, a good selection of screwdrivers, a set of Ratchets, and a set of wrenches, along with a variety of other tools. Can be a chunk of change for the initial purchase, but your pretty much done for basic hand tools for life.
One Craftsman power tool that I am a big fan of(the wife bought it, but it turned out great), is the Craftsman 5in1 tool. It's basically a big, heavy dremel with a number of attachments. It comes with a small plunge router base, a D-hamdle base, and bases for flat and angled spiral saw cutting, and a circle cutter(great for ceiling fixtures), if your not familiar with spiral saws thats what the Zipsaw is. But it's real benefit is that it is(especailly with the optional extension handpeice, the biggest baddest Dremel type tool you will ever use. I've used it with a sanding drum(bigger than the normal dremels will handle) for literally hours at a time, without it heating up at all. It looks kinda cheesy, like most supposedly multi purpose power tools, but really is a great tool.
Jon
