Basic scales question
I want to try putting my own scales on a bare steel fixed blade knife. My question is what kind of fasteners would be best for a beginner to try. I don't see how pins work, why don't they fall off?
I have basic woodworking skills, but I have a question about using wood. Wood is porous. Steel rusts. Is it possible to make it so the scales can be removed? Should I worry about what is happening under the wood over time? Or is this a glue, screw and tatoo situation? Is that a dumb question?
I appreciate any direction, and don't mind at all if my questions are the source of amusement!
Dave, I'm sure there are other that could give you better advice but here is my $0.02...-
Your choice of materials is as important as your fasteners or methods of bonding. Choose either a wood that is naturally stable such as cocobolo, lignum vitae, olive wood, rosewood, etc or have your choice of wood stabilized to reduce/remove the possibility of movement. Using a quality epoxy such as G-Flex or AcraGlass will form a waterproof barrier around the tang and assist in chemically bonding the scales to the tang. If you have a good woodworking background I also suggest that you use corby or loveless bolts which need to be countersunk. If you're not ready to try these bolts, regular pins will work if epoxied in place. The pins add strength and keep the scales from shearing off.
This link will take you to NorthCoastKnives where there are a number of tips and tutorials for beginners. http://www.northcoastknives.com/northcoast_knives_tutorials_hints_tips.htm
This link is to a supply house that sells the hardware you'll require. http://usaknifemaker.com/catalogsearch/result/?q=loveless+bolts
I hope this helps.
Mike
