I found this on net and I think that many here would like to read
By STANLEY ZINN . . . .
When induction hardening ferrous metals, quenching is just as important as the proper heating of the metal. Inadequate or improper quenching of the heated part results in low hardness values as well as spotty hardness and may cause quench cracking. The intent of the quench is to cool the already austenitized material at a rate that converts most of the austenite to martensite.
Grain size of the material is a major factor in conversion of the metal into austenite and then martensite. The smaller the grain, the faster the material will go into solution. Smaller grain sizes reduce the time required at temperature and the temperature necessary to go into solution as well. Accordingly, rolled, forged, annealed or previously quench and tempered materials will all be affected differently by the heat and quench cycles.
There are a number of methods that can be used for determining the cooling rate for a given alloy. These include the Jominy Hardenability curve (JHT); the Time, Temperature, Transformation curve (TTT); and the Continuous Cooling Transformation (CCT) curve, all for the specific alloy being processed. Usually, the process at 704°C(1300°F) is used as a measure of the material's hardenability.
There are a number of quenchants that are used with induction heating and they are selected according to the materials being processed. This selection is based not only upon the material selected but by the mechanical configuration of the part as well. Where masses vary rapidly in volume (change from shape to shape) it may be necessary to use a less rapid quench to prevent cracking at the interface of the two shapes.
Quench cracking is caused by the formation of stresses within the part due to the normal contraction of the metal as it is cooled. In addition, microstructural stresses also occur as the steel expands with the formation of martensite.
Quenching is designed to remove the heat of the part as rapidly as possible. The quenchant must bring the material temperature below the knee of the TTT curve before the structure returns to an austenitic condition. The basic problem incurred during quenching is the formation of steam or vapor at the surface of the part as the quenchant comes in contact with the hot metal surface. It is important that the steam be broken down as rapidly as possible so that additional quenchant can contact the surface and reduce the part temperature. Breaking down the vapor barrier on the surface to be quenched eliminates soft areas and reduces residual stresses that may lead to quench cracking.
Quenchants are generally rated by their ability to remove heat, with brine being the most rapid and oil being the slowest. Where feasible, water is commonly used as a quenching medium. The key to adequate quenching lies in the thermal conductivity of the quenchant and its flow against the heated surface. Brine removes the heat at the fastest rate. Oil is considerably slower. The reaction time of certain steels precludes the use of rapid quenchants such as water which can produce cracking. Selection of the proper quenchant for each type of steel can generally be found in most metallurgical tables.
Oil can be used as a quenchant if it is used in sufficient flow so that the BTUs removed from the part, per gallon of quenchant, is kept below the ignition temperature of the oil. Thus, flow is more important than pressure in oil quenching. However, oil is rapidly being replaced as a quenchant due to its fire hazard and the smoke generated during the quenching cycle.
Plastic or polymer quenchant additives to water are replacing oil as a cooling medium. The “quenchability” of the system is dependent on the percentage of polymer in the water. The greater the polymer concentration, the slower the quenching action and the lower the BTU removal rate of the quenchant per gallon. Since heating of parts causes the water to evaporate during the quenching cycle the concentration must be monitored constantly. This is done utilizing a refractometer which can indicate percent concentration by measuring light diffraction through a sample of the quenchant. Some automatic systems are now available which will monitor the system and maintain the polymer concentration.
Polymer additives have a sticky residue and when used with automated equipment, cleaning of the quench system is important, especially if the equipment is not utilized for some period of time.
In all cases, quench flow is the important factor. High pressure causes the stream to impinge on the surface of the part and does not effectively remove BTUs from the surface. A high flow rate, at minimal pressure is more effective.
Selecting a Quenchant
Brine
Brine cooling rates are the most rapid of all the quenchants. While steam (vapor) breakdown is extremely rapid, higher cooling rates may increase the possibility of distortion and quench cracking of the part may occur. Where the part geometry permits rapid quenching, brine quenching can eliminate soft spots.
This rapid quenching action is caused by minute salt crystals that are deposited on the surface of the work. Localized high temperatures cause the crystals to fragment violently, creating turbulence that destroys the vapor phase.
A 10% solution of NaCl is usually an effective quench. The relationship of brine concentration to hardness is shown in Figure 1. Small variations in quench temperature will not greatly affect the cooling rate of the system. A temperature of 20°C (68°F) assures maximum effectiveness of cooling.
Water
Water quenching is the most common of induction quenchants. Cold water is one of the most severe of the quenchants and rapid agitation allows it to approach the maximum capabilities of the liquid quenchants. If the temperature of the water is allowed to increase, its capabilities for reducing the vapor phase drops and the cooling rate will also decrease at a rapid rate.
Water quench temperatures should be in the range of 15-25°C (60-75°F) as shown in Figure 2. To maintain adequate cooling provide agitation of the fluid to create a velocity in the order of 0.25 m/s (50 ft/min). It is usually recommended that along with rust inhibitors, biocides should be added to water quench systems to eliminate biological growth in the water.
Oils
Oils are characterized by quenching speed and operating temperature among other factors. Oils range from normal speed for quenching high hardenability steels to high speed for steels with low hardenability (see Figure 3). A major factor in selection of oils is the flash point or temperature at which the oil vapors will ignite if an ignition source is present. Ignition occurs if the part is not quenched rapidly or if the oil does not remove heat fast enough. Rapid agitation of the oil together with an adequate cooling means in the quench tank are necessary to reduce the possibility of fire.
Polymers
Polymer quenchants are aqueous PVA materials that are added to water to simulate the quenching characteristics of oil. This is obtained by varying the concentration of the polymer in the water. Benefits of this system include the elimination of smoke as well as possible hazard of ignition and fire.
The polymer helps develop a film at the interface of the heated material and the quenchant and acts as an insulator to slow down the cooling rate to approach that of oil. This film eventually collapses and the quenchant comes in contact with the part being processed. This results in nucleate boiling and a high heat extraction rate. The balance of the cooling is due to convection and conduction in the liquid.
The polymer film on the surface of the heated area dissolves into the fluid when the surface temperature of the part falls below the separation temperature of the polymer quenchant (see Figure 4). A range of quench characteristics can be achieved through variations in the concentration of the polymer, quenchant temperature and agitation of the quenchant.
As the water vaporizes due to contact with the heated surface it will vaporize and turn to steam. Accordingly the concentration of the polymer tends to increase in the quenchant over time. This will change the characteristics of the quench and the addition of water and/or polymer must be adjusted regularly by checking for proper concentration.
Polymers are completely soluble in water at room temperatures but insoluble at temperatures ranging from 60-90°C (140-195°F). Adequate cooling of the quench fluid to remove heat must be provided to keep the quenchant in this range. Agitation of the polymer quenchant solution will also aid in maintaining uniformity of quench.
