- Jan 25, 1999
Strider GB.
The plastic with deform readily, a large Voyager is much more robust.spyder8 said:can a twistmaster b used?
Not if it behaves like the Point Guard I handled, even the LAWK's is easily collapsed....or how about a crkt m-16?
Was the knife damaged?stratocaster said:Reading the articals I get the sence that these are last ditch survival techniques. They will indead work, but are considered (even by the author) to be abuse to the knife.
Collapse the lock if that is a real concern :Scott Dog said:I would think that doing that aggressively on a routine basis would be hard on just about any folder.
It doesn't take much wood to prevent you from just being able to press/rock the knife through it, unless you want to whittle it off in shavings.Even just light batoning as in wrist/elbow swings will allow you to cut much more wood than just pressing the knife through it.I assume the reason you want to baton is that you are planning to use it in an aggressive manner or at least you plan to use it to cut something that can't be easily sliced.
How hard are the swings, wrist, elbow, shoulder or back? Small baton like a broomstick or larger like a 2-3" stick.Critter said:That is correct, and the technique is certainly not abuse in any sense, at least with regards the RSK MkI or any other well constructed reasonably robust folder.
Well, we went at it with vigor using about a 2-inch baton and split a bunch of wood, going through a few batons in the process. I suppose if you really wanted to and were a gorilla, you could do some damage to the knife. With concerted effort you can destroy anything. Once saw someone try batoning with a rock.Cliff Stamp said:How hard are the swings, wrist, elbow, shoulder or back? Small baton like a broomstick or larger like a 2-3" stick. -Cliff
Thanks. I am a bit confused, and I can't say we batoned with it into anything particularly wierd, but some of the wood was also not nearly perfectly straight. Beyond that, I'm not sure I understand what you are after. The trick with batoning is to let the knife and baton do the work and not get impatient and try to twist the blade, on either axis, to split the wood. Another common mistake is to try and do too large a split. Patience and moderation are very much virutes in such wilderness skills, partiuclarly when usin g a folder vs a fixed blade, but even then a slim fixed blade can be easily damaged or broken if one is not careful.Cliff Stamp said:Thanks Doug, on a knife that size, as you noted there would be grip stability issues with really heavy force plus the blade isn't so large enough that you can get really wide swings like you can with a 10" camp bowie and be precise, well I can't anyway so then your extra energy isn't fully utilized.
My main concern would be can you just take clear wood or can you handle the extra effort it takes to split around twisted grain. Can you baton with the same effort you would use on a small puukko for example? I should get some mpegs made to enable clearer communication. I really like the design by the way, no speed holes.
Well, there's the Gatco Mini-X which is essentially what you describe, though with a single fixed angle. It is not a typical pull-through vee sharpener, contrary to most folk's expectations, but is used much as a Spyderco Sharpmaker is. We also have some ceramic coated aluminum sharpeners, though they currently use a pair of carbides as a primary sharpening tool. In any case, I have been looking at some sharpener ideas for future development, just a question of time to work further on them.Cliff Stamp said:You should develop a mini-sharpmaker with Spyderco which is more packable and mainly for smaller blades. Cut down on the options as it is mainly a touchup kit so you could really trim out a lot of the features of the full Sharpmaker, sissor sharpening, etc.
You could cut the length of the rods in half for small folders, or dual sinter them (half medium, half fine), to reduce size / weight. You would also want a well padded package as ceramics don't take to being banged around, or do a mild steel ceramic covering which is far more durable.
In regards to twisted grain, some woods like apps is very clear with open grain, so much so you can basically let an axe fall on it and it splits. You can take fairly decent sized rounds, 4-6" and just whack them with a bowie and they split. Cedar is like that as well, pine similar when clear but it usually isn't.Critter said:I'm not sure I understand ...
In most cases, you can't really apply much force because there is nothing holding the wood in place. You are pretty much constrained to just using your wrist. Leveraging the knife up and down or attempting to rotate it would do little to the knife or wood,...not get impatient and try to twist the blade, on either axis, to split the wood.
It is more of an unplanned thing, make do with what you have.OTguy said:Would like to understand why you need a folder for this ...
Cliff Stamp said:It is more of an unplanned thing, make do with what you have.
-Cliff
