You can do that with the tree still standing if you want. Its easier and you get a lot more fire wood....You don't need a knife at all...just use your saw.
It was good enough 100 years ago, its good enough now....
The object of this so-called bushcraft is to know how to do things when out in the woods.
Relying on one tool if you don't have to is not a good idea....you know, that thing about eggs and baskets and all....
Probably going to need a vid of batoning cucumbers with crescent wrenches. Am I the only one??I use my tools however I want.
He didn’t design it. It was designed long before he was born, by Horace Kephart.
Thats not really a saddle axe. Its a small double bit hatchet, maybe 11" overall, way too small to be a saddle axe.I know he has his opinion, but that doesn't make others any less valid. And he's probably one of the very few to choose a saddle axe as the best option, even in his day. They're actually not so easy to get these days, with only 3 options I've found when trying to procure one recently, and 2 are from council tool. Coincidently, even 140 years ago he was writing about the horror of people using big knives to get the same work done. Just as hot of a topic back then as it is now.
Absolutely, he did way more outdoors activities than I'll likely ever be able to do, but his choices in tools are not the Holy Grail either.
In many parts of the world, only a machete is used. That's a real survival edged tool there.
This ^ A bacho Laplander or even a COrona 10 inch paired with a decent sized knife can do pretty much everything you typically need.
TwoHawks makes a really nice verwion BTW....
Either way, I prefer the small GB hatchet
What you use is often dependent on your environment. The hardwood forests of the North East aren't really conducive to machete use.....
Using the other knives in the wood etch as scale (the folding knife is a large moose pattern, probably made by Napanoch or NYK Co, about 4 1/4" long), the hatchet would be approximately 10-11". The similar sized head on the 2Hawks hatchet is a bit under a pound at 14 oz, so definitely a lot smaller than a real saddle cruiser....A typical small Warren saddle cruiser made when they were actually in common use had a 19" handle and a 2 lb head. Those tiny 1lb axes are sometimes referred to as double bit trapper hatchets.Accounting for Sears being a tiny human, definately not way too small to be a saddle axe unkess he was running a really small head weight too (I've never actually looked to see what size head he used). By the specs at least, a saddle axe is essentially a double bit hatchet. 16" handle, 2lb head weight, at least that's the CT saddle axe's specs. Maybe they should've just called it a double-bit hatchet.
I never could like that one...Rc of only 50-54, weighs over a pound, at that price the GB mini is a lot better....The tiny Knives of Alaska Hunters Hatchet is really compact and nice for limbing as well as making kindling. Nice little tool.
A situation I’ve been in is called winter, here in Canada we get 4-5 feet of snow in the winter months so as you can imagine it’s pretty hard to get kindling…. However if you look hard enough you can find bone dry sticks on the bottom of evergreen trees. But that’s if you’re in a evergreen forest in hardwood forests there’s not a lot of evergreen trees but what there is a lot of is dead falls, so it’s better to cut some wood with your saw then to baton it. In my opinion of courseCan you think of a situation you have been in where there were no sticks or twigs or any other way to get kindling, but there were handy burnable logs lying about for you to split with a knife?
I love my GB Forest axe over my others, but when loaded down with stuff felling trees, the tiny one has come in handy. I will have to look at the GB mini.I never could like that one...Rc of only 50-54, weighs over a pound, at that price the GB mini is a lot better....
Here in New England there are tons of dead falls right now...most of them being ash trees. When they fall, dead ash trees pretty much explode into small bits. No cutting or batoning required......A situation I’ve been in is called winter, here in Canada we get 4-5 feet of snow in the winter months so as you can imagine it’s pretty hard to get kindling…. However if you look hard enough you can find bone dry sticks on the bottom of evergreen trees. But that’s if you’re in a evergreen forest in hardwood forests there’s not a lot of evergreen trees but what there is a lot of is dead falls, so it’s better to cut some wood with your saw then to baton it. In my opinion of course![]()
