- Jan 28, 2006
I'm going to do what I do best and step on toes.
For those that contend that batoning a knife through a piece of wood is safer than axe use are using the axe wrong (and the way they describe using the axe proves this).
Complaining about weight? A 19" bushcrafting axe weighs about the same as the big boomer knives, with a lighter sheath and are more efficient due to the weight being concentrated right behind the cutting edge. The smaller axes are generally lighter than the big boomer.
Tomahawks can't work wood? I suffered this delusion before until a certain Vector001 challenged me to try doing things his way with a long hafted trail hawk. Lo and behold, those little buggers work quite well, thank you very much. Again, I have to lay this at the feet of not really knowing how to use the tool.
Let's be honest. This is a hobby, no one on these boards HAS to do this to live. If you WANT to baton a knife to split wood, that's enough reason. If you WANT to use an axe or a tomahawk, that's also your prerogative. Neither answer is wrong as both accomplish the task.
Eventually you'll come to your senses and realize that a kukri is the superior tool, anyway. . .
