Batons
I know there are a lot of quality wooden batons on the market but what other materials are good for batonning our knives through wood? I have some left over 1" diameter delrin dowels that I was thinking of trying. Would that be considered to hard and thus be considered abuse?
Thanks.
i used a 5lb sledge once, wouldnt recommend that.
is one inch dowel heavy enough? if it isnt metal i wouldnt worry about damage to the blade temper.
The dowles feel pretty heavy and should work for light camp work. I do not have to worry about splitting 10 cords of wood every winter?
I used to use a rubber/plastic mallet on a BM-E I used to have. Worked o.k. but I stopped when you guys made fun of me. :p
Rolled up rawhide will work, as will rubber tire mallets, just be mindful of deflection with the latter.
I don't think delrin would be any worse than a good piece of hickory. If in doubt, wrap a piece of leather around the striking area, something in the 8 to 12 oz thickness ought to do well, or a good piece of rawhide or kydex. It will wear out, but should protect the spine etc.
heck, i used a metal sledge, so im the last one who would make fun of you. :)
as long as there is enough weight, should be fine. is delrin a type of resin or plastic? it may crack or break under the power of infi.
Delrin is a pretty durable plastic. I started using it training Eskrima because we always broke rattan, kamagong, diamond wood, etc... It held up really well. But against INFI... I am not so confident. We need a Busse Baton. I'll have to check the heft my scraps have though. I might have to visit the local hardware store for an axe handle. :)
how about a kid's size wood baseball bat?
You mean all this time when I was cutting a baton out of a tree I was going to cut down I was doing it wrong. Crap I Need a rubber mallet now. :)
I just use whatever is lying around....Spare piece of firewood usually.
I thought everyone did that....:confused:
I didn't want to sound like an idiot so I was withholding my post until someone else mentioned it ;)
I usually use a piece of wood laying around or you could make one yourself
:D:D
You mean you guys don't fork out $$$ for something you could just pick up off the ground for free. ;)
Great idea about using a piece of firewood. But being a city boy I usually buy the small bundles from the local store. And most of the pieces of wood are too wide to use as a baton. At least for my hands. But I guess once you split a piece once or twice you end up with a manageable size of wood to use.
nothing wrong with a dedicated baton, i had never though of that. i may just pick up a cheap baseball bat.
I always use an old machette I hit spine to spine, all wood can hurt your hands and really vibrate bad. The SJTac I always use has no damage from the metal on metal contact but the machette is pretty messed up. Ive split hundreds of logs with it. Plus the machette has a handle, easy to use with gloves and wet hands.
Ditto. A piece of wood lying around. "...wood can hurt your hands and really vibrate bad." I just take another drink and keep on bashin' the sh!t out of my splittin' blade!!
:D:D
Nice. Let old Heavy take the chance...:grumpy:
:D
Tire knocker would work. I have a small (smallest I have seen that was intended for actual use) wooden kid's sized baseball bat that lives out by the woodpile that worked well.
THe smaller of the two (I know, I know, blaspheme) of the new cold steel "bats" might be a functional tool.
