- Jun 1, 2012
SUNWAYMAN has just released three awesome new lights.
The 18650 powered (1 x 18650 or 2 x CR123A's) tactical T21CS features a tail cap switch and side-switch, an integrated charge port, and a 600 lumen output from its CREE XM-L U3 LED. A deep, smooth reflector projects the beam up to 300 meters.
The R10A and R10R are compact Every Day Carries. The R10A runs on a single AA or 14500 cell and can generate up to 205 lumens with the Li-ion power source (140 lumens with AA battery). The slightly shorter R10R is powered by 1 x CR123A and can produce the same 205 lumen output. We're still waiting for some more details on these elegant EDC's and will keep you updated as the info comes in.
All Three are available for pre-order today!
Features:
Specifications:
Features:
Specifications:
Features:
Specifications:
Features:
- Tactical tail switch interface coupled with side switch
- Constant circuit maintains constant output
- Built-in charging module charges li-ion 18650 battery (Does NOT Charge 16340 or RCR123A cells)
- Smooth metal reflector
- Aerospace-grade aluminum alloy production
- Military Spec Type III hard anodized body
- Ultra-clear tempered glass lens
- Includes: Charger, Holster, O-ring, rubber cap, plug, lanyard
Specifications:
- LED: CREE XM-L U3
- Runs on: 1 x 18650 or 2 x CR123A cells (NOT Included)
- Working Voltage: 3~8.4V
- Output/Runtime:
- Turbo: 600 lumens
- High: 350 lumens/2.4 Hours
- Medium: 75 Lumens/12 Hours
- Low: 8 Lumens/104 Hours
- Peak Beam Intensity: 2400cd
- Dimensions:
- Length: 6" (153.8mm)
- Head Diameter: 1.8" (41mm)
- Tail Diameter:1.18" (30mm)
- Weight: 5.75oz (163g)
Features:
- Compact Size
- Elegant design
- User-friendly interface
- Aluminum construction
Specifications:
- LED: CREE XP-G2 R5
- Runs on: 1 x 14500 Li-Ion battery or 1 x AA alkaline battery (NOT Included)
- Output w/14500 battery: 205 lumens
- Output w/ AA battery: 140 lumens
- Dimensions:
- Length: 3.98" (101mm)
- Diameter: .88" (22.5mm)
Features:
- Compact Size
- Elegant design
Specifications:
- Runs on: 1 x CR123A cell (NOT Included)
- Output: 205 lumens
- Dimensions:
- Length: 3.36" (85.5mm)
- Diameter: 0.88" (22.5mm)
