BatteryJunction.com- NEW Nitecore TM15 - 2450 LUMENS & Rechargeable!
Feedback: +0 / =0 / -0
Nitecore has improved upon the already incredible Tiny Monster with the brand new TM15. Three XM-L U2 LED's produce up to 2450 lumens. Integrated thermal protection allows the TM15 to run for up to an hour in turbo mode, and 52 hours in its lowest (95 lumen) setting. An intelligent charging circuit with status detection makes powering the light efficient and convenient. The TM15 runs on 4 x 18650, or 8 x CR123 batteries, so you always have to option to recharge or reload.
The TM15 is available for pre-sale today, and should be in our warehouse within two weeks!
Specifications:
  • Dimensions:
    • Length: 6.22" (158 mm)
    • Bezel Diameter: 2.36" (60 mm)
    • Body Diameter: 1.96" (50 mm)
  • Weight (Excluding batteries): 15.76 oz. (447 g)
  • Output and Run Time:
    • Turbo: 2450 lumens (1 hour)
    • High: 1300 lumens (3 hours, 10 minutes)
    • Mid: 570 lumens (8 hours, 20 minutes)
    • Low: 300 lumens (16 hours, 30 minutes)
    • Lower: 95 lumens (52 hours)
  • Maximum Throw: 1,190 feet (363 m)
  • Peak Beam Intensity: 33,000 candela
  • Impact Resistant to 4.9 ft. (1.5 m)
  • IPX-8 Water Resistant
Features:
  • Integrated thermal protection prevents overheating
  • Compatible with both 18650 Li-Ion and CR123A Batteries
  • Intelligent charging circuit with status detection recharges the light easily, safely, and quickly
  • Exceptionally long run times
  • Innovative power indicator light displays remaining battery power
  • Single button two-stage switch provides a user-friendly interface
  • Coated mineral scratch-resistant glass lens
  • Aluminum reflector ensures consistent and powerful beam
  • Consructed from military grade HA Type III hard-anodized aluminum alloy
  • Accessories: Charger, holster, lanyard, and spare O-ring
