- Jun 1, 2012
BEHOLD! Nitecore's newest addition to the Tiny Monster series! The 3500 Lumen TM26 Quadray features 4 cores of the CREE XM-L U2 LED and 8 settings, including a strobe, beacon flash, and SOS function. Nitecore also included an ultra-low 3 lumen mode for close-quarters navigation. Recharging capabilities and an integrated multi-function OLED display screen add the perfect balance of brains to the TM26's brawny output.
The OLED screen displays lumen output, brightness mode, battery status, battery voltage, approximate runtime, and temperature.
The TM26 comes with an AC charging cable and is compatible with the TM15's car charger.
Pre-Order yours Today at BatteryJunction.com!
Features:
Specifications:
Features:
- The world's smallest 3500 lumen LED-flashlight
- Integrated multi-function OLED display
- Thermal protection circuit prevents overheating
- Compatible with both 18650 Li-ion and CR123 batteries
- Intelligent charging circuit with voltage detection charges safely and rapidly
- Exceptionally long runtimes using 4 × 18650 Li-ion or 8 × CR123 batteries
- Capable of using 1 × 18650 or 2 x CR123 batteries in emergency situations
- Eight rapidly switchable brightness levels and modes to select from
- Innovative single button two-stage switch provides a user-friendly interface (Patented)
- Toughened ultra-clear mineral glass with anti-reflective coating
- Integrated Precision Digital Optics Technology provides extreme reflector performance
- Stainless steel bezel-ring protects core components from damage
- Constructed from aerospace-grade aluminum alloy
- HAIII military grade hard-anodized
- Waterproof in accordance with IPX-8 (submersible to two meters)
Specifications:
- LED: 4 x CREE XM-L LEDs
- Runs on: 4 x 18650 lithium ion cells OR 8 x CR123 batteries (NOT included)
- Output/Runtime (4 x 18650's):
- Turbo: 3500 Lumens/45 min
- High: 1700 Lumens/2.5 Hours
- Medium: 540 Lumens/8.25 Hours
- Low: 95 Lumens/48 Hours
- Lowest: 3 Lumens: 1000 Hours
- Output/Runtime (8 x CR123A's):
- Turbo: 3500 Lumens/1 Hour
- High: 1700 Lumens/2.25 Hours
- Medium: 540 Lumens/5.75 Hours
- Low: 95 Lumens/32 Hours
- Lowest: 3 Lumens: 750 Hours
- Dimensions:
- Length: 5.6" (142mm)
- Head diameter: 2.68" (68 mm)
- Head side-length: 2.24" (57mm)
- Tube diameter: 1.97" (50mm)
- Weight (w/o battery): 15.45oz (438g)
