- Jun 1, 2012
The SUNWAYMAN C15A Dolphin is an extremely capable compact AA light. A soft contact side switch interface is easy-to-use and cycles through three outputs, a strobe, and an SOS function. The Dolphin can run on either a primary AA alkaline or a Li-Ion 14500 cell. Reverse polarity protection and a low voltage-indicator add to this light's user-friendly features.
An XM-L U2 LED can produce up to 170 lumens in high mode, while up to 70 hours of runtime are achieved in the 3 lumen low setting.
The included detachable lanyard ring secures to the tail of the light through a threaded hole. With the lanyard removed, this can also be used to mount the flashlight on a standard UNC1/4'-20 camera mount.
With exceptional quality and design, the C15A offers great features in a compact light that is there when you need it.
Available for Pre-order today!
[*=left]Multi-function soft-contact push button side switch with three modes of output, Strobe, and SOS
[*=left]Low voltage indicator
[*=left]Physical reverse polarity protection
[*=left]Circuitry built with a broad voltage range allows for various battery types
[*=left]Detachable lanyard ring with a UNC1/4'-20 threaded hole for camera mount
[*=left]Includes: metal clip, spare o-ring, lanyard, holster
Specifications:
Specifications:
[*=left]CREE XM-L U2 LED with a lifetime of up to 50,000 hours
[*=left]Output and Runtime:- High: 170 Lumens (1.2 hrs)
- Medium: 30 Lumens (10 hrs)
- Low: 3 Lumens (70 hrs)
[*=left]Constant current circuit with constant output
[*=left]Effective range of 337' (103 m)
[*=left]Uses 1 x AA Alkaline, Lithium, Ni-MH or 1 x Li-Ion 14500 (Batteries not included)
[*=left]Working voltage: 0.9 - 4.2V
[*=left]High quality reflector maintains great throw and spill with a perfect beam pattern
[*=left]Dimensions:- Length: 3.66" (93 mm)
- Head Diameter: 0.98" (25 mm)
[*=left]Weight (excluding battery): 2.68 oz (76 g)
[*=left]Made of aerospace-grade aluminum alloy
[*=left]Military Spec Type-III hard anodizing
[*=left]Waterproof in accordance with IPX-8 standards
[*=left]Ultra-clear tempered glass lens that is scratch and impact resistant
[*=left]Can tail stand to be used in "candle" mode
