- Jun 1, 2012
The D40A from SUNWAYMAN is a brilliant and compact AA powered light. At under 5 inches in length, the 4 X AA device is extremely compact given its capabilities. The D40A uses an XM-L2 LED to produce up to 980 lumens in turbo mode. (Light steps down to 550 lumen high mode after 3 minutes)
SUNWAYMAN included two side switches, one for activation and another for mode selection. A deep reflector allows an effective range of 315 meters.
SUNWAYMAN has consistently released some of our favorite lights, and we're confident the D40A will be another hit. We expect these to come in by the end of May, and have listed them for pre-order already!
Pre-Order yours today at BatteryJunction.com!
Features:
Specifications:
Features:
- CREE XM-L2 LED, with a lifetime of up to 50,000 hours
- Brand-new Dual-button Side Switch System, slightly depress the side switch buttons for output ranging from 30 to 980 lumens
- Constant current circuit, constant output
- High quality reflector with soft beam pattern
- Optimized Deep Reflector, great throw distance as well as perfect beam pattern
- High quality aerospace-grade aluminum alloy, Stainless steel head retaining ring
- Military specification Type III- hard anodized body
- Waterproof, in accordance with IPX-8 standard
- Ultra-clear tempered glass lens resists scratches and impacts
- Tail stand capable- can be used as a candle
- Included Accessories: Lanyard, O-ring, Holster
Specifications:
- LED: CREE XM-L2
- Runs on: 4x AA (Batteries not included)
- Output/Runtime:
- Trubo: 980 lumens / .05h
- High: 550 lumens / 1.7h
- Mid: 220 lumens / 4h
- Low: 30 lumens / 31h
- Peak Beam Intensity: 24800 cd
- Dimensions:
- Length: 4.74" (120.6mm)
- Head Diameter: 1.57" (40mm)
- Body Diameter: 1.65" (42 mm)
- Weight (W/o Batteries): 5.83 .oz (165.4g)
