BatteryJunction.com - PRE-ORDER! Olight M18 Maverick- Tactical 500 Lumen Compact EDC!
Feedback: +0 / =0 / -0
Olight has added one more to its tactical M series. Last Month's M10 now has a big brother. The 500, lumen 2 x CR123A powered M18 Maverick is fitted with an XM-L2 Led. Like the M10, it's a reworking of the popular Baton series. The side switch is paired with a tailcap switch and stainless steel bezel for a more tactical feel.
Available for pre-order today at BatteryJunction.com!
Features:
  • Cree XM-L2 LED
  • Three adjustable brightness levels (low-medium-high) and 10HZ strobe
  • Multi-function tail switch: quickly double press the switch to activate high output; quickly triple press the switch to activate strobe; release to quit. Click the switch to confirm the output (high or strobe) and lock out the side switch.
  • Press side switch to change the brightness after powering on the light with the tail switch
  • Strong removable pocket clip
  • Thick stainless steel bezel protects the lens
  • Intelligent driver circuit with memory function automatically memorizes the output level last used
  • Aviation grade aluminum body with anti-scratch type III hard anodizing
  • Lens: Toughened ultra-clear glass with anti-reflective coating
  • Reverse polarity protection guards against improper battery installation
  • Low voltage indication: the bottom side switch will glow red when the power is low
  • Dual spring contacts for vibration and recoil protection
  • Includes: Lanyard, 2x Spare O-rings, Silicone tail cap
Specifications:
  • LED: CREE XML-L2
  • Runs on: 2x CR123a/1x 18650
  • Output mode/Runtime:
    • High: 500 lumens / 2h
    • Mid: 100 lumens / 9h
    • Low: 5 lumens / 120h
  • Peak Beam Intensity: 4,556 cd
