- Jun 1, 2012
Olight will be releasing a new addition to its legendary tactical line. The new M3X utilizes an XM-L2 LED and can produce up to 1000 lumens.
The M3X comes with two different sized battery tubes so it can run on 2 x 18650's (4 x CR123A's) OR 3 x CR123A's (3 x RCR123A's).
A tail switch allows for constant and momentary on while a twist of the bezel alternates between high and low modes.
AVAILABLE FOR PRE-ORDER TODAY!
Features:
Specifications:
Included Accessories:
Features:
- High performance Cree XM-L2 LED
- Maximum output of 1000 lumens and 580 meters in beam distance
- Two digitally controlled constant-brightness levels and a bright strobe
- Instant access to strobe
- Crenelated front bezel and tailcap designed for close-quarter combat
- Rugged aluminum body with scratch-resistant, indestructible Type-III hard anodizing
- Anti-slip knurling for excellent grip
- Active Thermal Management System (ATM) to protect LED and other components from high temperatures
- Smooth reflector providing perfect-beam with exceptional throw
- Shatter and scratch resistant anti-reflective double coated ultra clear lens
- Friendly user interface, change modes by rotating the head
- Water resistant to IPX-8 standards
- Extra extended tube to prolong the runtime
- Removable stainless steel clip
- Mountable on firearms using a compatible weapon mount
Specifications:
- Battery Options in 3-cell Configuration (Batteries not included):
- 3 x Lithium CR123A / Li-Ion RCR123A
- 2 x 18650 Protected Li-Ion
- Battery Options in 4 Cell Configuration (with included extender tube) (Batteries not included):
- 4 x Lithium CR123A (Note: 4 x RCR123A's CANNOT be used with extender)
- Dimensions: 2.48" (63mm) (Diameter) x 8.31" (211mm) (Length)
- Body Diameter: 0.98" (25mm)
- Weight: 9.38oz (266g) (excluding batteries)
- Output (Runtime):
- High 1000 Lumens (1.4 hours)
- Low 300 Lumens (5 hours)
- Strobe 10Hz (2.8 hours)
- 1 x Extended Tube
- 1 x Holster
- 1 x Battery Magazine
- 4 x Spare O-rings
- 1 x User Manual
- 1 x Warranty card
