- Jun 1, 2012
This light is a true beast. Six Cree XM-L T6 LEDs generate an unbelievable 5000 lumens in high mode! A precision crafted lens and reflectors project the beam up to 700 yards (~640 meters) - a truly staggering spec by any standard.
The high capacity rechargeable lithium battery is attached remotely to the main body for more comfortable weight distribution and heat dissipation.
Lightweight aluminum alloy and durable Bayer ABS plastic construction ensures a rugged and manageable device, even for extended use. A high-strength plastic and carbon fiber composite makes up the head cover, handle, and tail cap, adding to the light's toughness. Advanced cooling fins and a high-efficiency synchronous step-down constant current driver circuit keep the light from overheating so you can trust this gear to work every time for as long as you need it.
Order Now: http://www.batteryjunction.com/olight-x6-marauder.html
Features and Specifications:
Output/Runtime:
High: 5000 lumens/1.25hrs
Medium: 1200 lumens/4.5hrs
Low: 150 lumens/30hrs
6 Cree XM-L T6 LEDs
Split-battery design allows a perfect weight distribution and heat dissipation.
IPX-6 water resistance rating - light can withstand water projected at high speeds from all angles without harm.
Built-in high-capacity lithium battery maintains impressive runtimes at high brightness outputs.
Aluminum alloy 6N01-T6 with Type-III hard anodizing and Bayer ABS Plastic (20% carbon fiber).
Works directly with 110V and 220V AC electric supply
Lens: Tough ultra-clear mineral glass with anti-reflective coating
Power indicator:
Low: red light on and should charge immediately
Normal: yellow light on
High: green light on
Terminal Control Mode
Standard accessories: One X6 Battery Pack, two Lanyard Rings, one Strap, one AC Charger, one Power Cord for AC Charger, one Manual, one Warranty Card
-Roger
Output/Runtime:
6 Cree XM-L T6 LEDs
Power indicator:
-Roger
