- Jun 1, 2012
BatteryJunction.com - Upgraded Olight SR95S UT - 1350 Lumens with a 950 Meter Throw!
Just when you thought it couldn't get any better. The extremely powerful, limited edition, SR95 Ultimate Thrower has been UPGRADED with the SR95S UT. The SBT-90 LED has been replaced by a new SBT-70 for a maximum throw of 950 meters, and a brilliant 1350 lumen beam. The same advanced engineering that went in to the previous generation SR95's makes this an incredibly efficient search and rescue light. Monster outputs are sustained through a unique "Hollow Out" design for optimum heat dissipation. The high capacity rechargeable battery allows excellent runtimes while a handy voltage indicator keeps you on top of your power reserves.
This light carries on the Olight SR tradition of rugged Search and Rescue Devices with unparalleled power.
Pre-Order Today!
Features:
Specifications:
Pre-Order Today!
Features:
- Color: Black
- Material: Aluminum body with anti-scratching type III Hard Anodizing
- Charger: AC 100-220V 50~60HZ input. Recharge under constant current and voltage) C3A/8.4V
- Smooth reflector
- Lens: Tough ultra-clear tempering glass, with anti-reflective coating
- Striking bezel: Aluminum body with anti-scratching type III Hard Anodizing
- Large side switch for easy activation, even in thick gloves
- Features two gold plated, metal O Rings
- Anti-slip ergonomic knurling
- Beam intensity in center: 129600 candela
- Maximum throw: 950 meters
- Waterproof rating: IPX6
- Impact resistant up to 1.5 meters
Specifications:
- LED: Luminus SBT-70 LED
- Battery: 7800mAh 7.4V rechargeable lithium battery
- Output/Run Time:
- High: 1350 Lumens/115 Minutes
- Medium: 400 Lumens/10 Hours
- Low: 100 Lumens/48 Hours
- Dimensions:
- Length: 12.8" (325mm)
- Head Diameter: 3.5" (90mm)
- Body Diameter: 2" (48.4mm)
- Weight: 2.7 lbs (1230.5g)
