- Jan 16, 2009
Bawidamann Blades has teamed up with RMJ Tactical to create the Ragnarok Tomahawk. RMJ Tactical can be credited with really bringing the "tactical tomahawk" concept to the forefront as a viable, versatile tool for the modern age. All you have to do is look at some pics from the past decade of conflict around the globe and if you study them close, you will see some of the "go fast" dudes with a RMJ strapped to their kit. The Bawidamann/RMJ Ragnarok 14 is meant to be a super lightweight and easy to carry option well suited to both anti material and anti personnel roles.
-This fast in your hand tool features a main cutting edge as well as a penetrating spike on the reverse.
-The handle end is beveled for use as a prybar.
-Constructed of 4140 chromoly steel that has been differentially heat treated.
-Coated with the tough and corrosion resistant Cerakote finish.
-Great grip from the G10 scale grips from VZ Grips in Ragnarok texture as well as the subtle ridges on the sides of the steel handle.
-Adjustable paracord on the end allows you to "lock it in" to your hand for serious use.
-Comes with a custom Bawidamann Bolatron sheath set up with both quick detach as well as Bawidamann PUP Pull the Dot snap straps. Perfect for belt or MOLLE carry options. Price is $425.00 via PayPal to include shipping to continental US. Axe is unused and never carried. Thanks!
Specifications
-Overall Length: 14"
-Cutting Edge Length: 3 1/2"
-Thickness: .275"
-Weight: 1 pound, 6 ounces (without sheath)
Specifications
-Thickness: .275"
