Bawidamann Huginn Monkey Edge 3V
bstag1/75
Feedback: +27 / =0 / -0
Sale $350 PayPal f&f shipped CONUS via USPS Priority mail.
Copied from Monkey Edge.
Take the fast, lightweight Huginn and mix it with super tough CPM-3V, and you get a tough as nails EDC fixed blade that can tackle fine cutting tasks as well as heavy use and abuse!
The Huginn: The Huginn is a super lightweight design from Bawidamann, and has a special emphasis on concealed carry, defensive fixed blade roles. The thin blade is perfect for your every day needs, and the almost hissatsu tanto/Wharncliffe hybrid upswept profile excels at slicing. This one has a sharpened upper edge! Don't worry about using and abusing that blade though, because it's ground from ridiculously tough CPM 3V! The 'Chunked' handle is made from Bawidamann's proprietary carbon fiber blend, and the texturing adds extra grip. The unique shape helps keep the knife locked in place whether in a standard or revers grip. The thin slicey blade and carbon fiber grip means for a super light and lightning quick blade! This variation features Bawidamann's killer acid etch finish with cobalt blue coloring!
Scabbard: One of the great features of Bawidamann Blades are the custom formed from Boltaron scabbards. A good amount of thought and design work went into making a practical and versatile carry system. The sheath comes with a Discreet Carry Concepts inside the waistband clip. Easy to set up for left or right side carry, with edge forward or edge rearward setup, and at a variety of angles.
Please Note: Each one of these blades is hand finished and the process for the etch means each one is going to look different. Different etch patterns, different colors, etc. We group them into similar variation, but don't be surprised if yours looks a little different, has more 'blue' or 'gold' colors than the ones pictured. That is the POINT of this finish, and what makes them unique!
Specifications
  • Overall Length: 8.125 in
  • Blade Length: 3.75 in
  • Cutting Edge Length: 3.625 in
  • Blade Thickness: .105 in
  • Weight: 3.8 ounces (without sheath)
  • Blade Steel: CPM 3V
  • Handle Material: Carbon Fiber Scales
  • Sheath: Boltaron Uber scabbard w/Discreet Carry Concepts Clip
Upper knife is Huginn
