Bear the Dog=Does Not Own a Hatchet!
Its true I don't have one but I am thinking of getting one. I feel like the only one on this forum that doesn't own a hatchet or Gossman knife. I don't know crap about them. Someone school me. Whats good? I don't want an axe just a hatchet. I won't be hiking with one but still want a light, durable cheap tool for splitting wood for the fireplace and some Bushycrafty!
Fiskars
GL Drew belt axe
Whetterlings
G & B
Gerber
Kershaw
Ranger
Estwing?
Give me some reasons why too.
I don't own any of the above except the fiskars I got it off amazon for 20 bucks and it has served me well simply put it's the mora of axes...
Gerber Gator. Extra knife in the handle, pretty good poll for hammering, and cheap.
A hatchet is useful for hiking and carrying when a light chopping tool is warrented. It is a definite compromise when it comes to dealing with large quantites of wood. If your intended use is for splitting wood for the fireplace, then you actually want an axe or even a splitting maul (depending on the size of wood) as these are the right tools for that job. They are heavy, but do an amazing job at splitting and due to their length are actually much more safer to use than a hatchet especially if you are just learning your swinging technique.
Gransfors Bruks makes quality axes and hatchets. They are basically the Busse's of the axe world and cost the most. However, an exepensive axe is only in the ballpark of $100so it really isn't that much to spend if quality and fit and finish are things you desire.
Whetterlings and Fiskars come to mind as tier II. The whetterlings is basically same quality materials as G&B but poorer fit and finish. They don't come as sharp and often do not have straight grinds on either side of the blade. If you buy one you will have to do a bit of work, to a larger amount of work, to get it to where the G&B comes from the factory.
Fiskars are quality little choppers with an ugly composite hollow handle. Gerber is identical to the fisker and made the same, but being all black is a little less ugly. You can even get a gerber that holds a crappy gerger knife in the hollow handle and watch it shoot out at ya as you swing the thing :) Lots of people love the Fiskers and Gerbers and I think they are lighter than the equivalent sized whetterlings. Both of these cost around $30 and up to $50 for ax lengths. In this same category you can also look at Buck which has a little hatchet that is by all means equivalent to the small fiskers and Gerber camp axes.
Ranger's hatchets are bomb proof but more designed as an entry tool to rip apart cars and doors than they are for bush craft and wood working. The spike on the back is more of a crow bar and wouldn't be all that good at hammering which the back of a hatchet is often used for.
The Drew belt axe is a gorgeous looking little thing, but more of a pocket sized instrument. Much smaller than any of the above. It is even more of a compromise than the above hatchets for chopping wood but it is really designed for the hiker in mind and will chew wood better then most knives of equivalent weight.
Estwing sportsman's hatchet is a metal hatchet with a leather handle. They look pretty good and have a good following. They are better than the no-name carbon hatchets at the hardware store but I don't think they are quite as good as fiskers and whetterlings. I've never seen one sharp before, although I imagine it can be made sharp. They run about $40 dollars and I think the Fiskar's are a better buy. I've used the larger estwing axes and I tend to like them quite a bit. You can usually find these at home depot or other common buisnesses (same as fiskers) so lots of people have them.
Kershaw's probably have the same performance as the estwing but most people who comment about them on these forums don't usually have all that much good things to say.
Personally I don't like the feel and balance of all metal axes. They just don't feel right in my hand. The hickory handles feel the best to me and I like the classic looks of them. The hollow composite handles feel okay to me but I hate their looks.
I have a GB hatchet and love it. In addition to all purpose choping, I've fashioned bowls with it. Like someone else said, you usually don't need to split wood in the bush. The exception is if it's wet and you're trying to create some dry kindling. The GB does that fine.
KGD,
Great post, very informative. I own exactly one hatchet and I FOUND it. Mac
I have a estwing hatchet.
Bear, if you're willing to do some reworking of the edge, you can get a mighty fine hatchet from wetterlings. Nice ash handle and all. Be sure to sand the laquer off of it so it won't give you blisters. You might find that a small knife and a hatchet is a better hiking pair than you think.
Bear,
Most of the pics I have seen of places you hike have been either jungle, or very open and rocky without a lot of trees.
I don't even ever recall seeing a fire or fire ring in any of the camping pics.
Maybe you don't need one:confused:
psy-ops - what a lazy estwing you have there - letting that knife do all its splitting for it!
Bear I think that fiskars incident was the exception rather than the rule I've used mine alot out in the cold with no ill effects... I have wanted a weterlings for a while and mora makes a neat looking little axe as well.
Need? We don't need no stinkin' need. This is Balde forum. If it has a blade we must have it, Period.
Bear, I'll chime in with what most are saying about Gerber/Fiskers, good, reliable and inexpensive. I don't use it all that much so being inexpensive was a plus. I'd rather spend more on other gear and knives.
Paul
:thumbup:I got an old Estwing at a tag sale with a rotten leather washer handle. Replaced the handle with a 550 cord wrap and have used it for 20+ years. It lives in the B.O.P.U.-[bugout pick up]. Best 2 $ I ever spent-KV
I own a Estwing,like psy-ops pic...I have owned it for nearly 20years and no isues, I like it due to it is made of sturdy material and has lasted for all these years without a single hiccup and easy to sharpen.
I saw that thread a week ago of the Fiskars that broke and it scarred me.
Don't be.
I've abuse mine for years and it is still in one piece. I've used two-hand swings, and, (in my best Scotty) "givin' it all shes got". Thrown it. Dropped it. Dropped logs on the handle. Its a tough sum-b...
I think that one in the other post was defective.
Chris
I kinda agree with HD. buy if you want one there are a few things to think about
Cost They start low and keep going
Handles Wood Steel Fiberglass
on the handle is it wet or raining alot I might just want an estwing with the old blue handle, good grip rot resistance
on handle does the looks matter to you, a new wood handle looks warm and friendly to use compared to modern materials
size hatchets range from about 8 to 18 inches, if it is home by the fireplace bigger could be better, but if you are gonna pack the thing it could be a boat anchor.
I have a wetterlings and some estwing they are both good but my favorite hatchet is an old KEENKUTTER that most would like because it has those dreaded nail pulling ears.
[/IMG] Pat
Snow & Neally Penobscot Bay
Hudson Bay type head, small enough to be use done handed, large enough to use two handed.
