- Oct 27, 2005
I've decided to begin selling off some of my bearing grade steel (I have about a dozen rings from 6" diameter up to about 14" diameter. Soon you'll be seeing threads with 52100 rollers being sold. I'm also going to be cutting up my bearing rings and selling it in different sizes. The reason for this thread is to help me decide what sizes and shapes would be best for me to cut them and forge them into. I'm know that many of you have power hammers and presses and would only like to purchase an entire ring or section of a ring and do your own forging. Others, especially those of you that don't have power hammers and presses, would probably like to purchase rollers, flat bar or round bar. I can forge them to any shape and size.
I've attached some photos of some of what I have.
I'm asking for guidance, to help me decide how to prepare the bearing rings for you. If you're interested in this steel, would you be most interested in:
I'm going to be sending a sample of each ring in for analysis to determine the exact steel type and will provide the chemistry with each purchase. The materials that I'm expecting them to be are 52100, A485-1 and A 485-2. When offered for sale, the steel will be identified in the for sale thread. I'm including the chemistries of what the three steels are for your information. The heat treat for all three steel types is the same. Just treat all three as you would 52100. The 52100 is the shallowest hardening steel of the three and the A485-2 is the deepest hardening steel of the three.
A485-1
Carbon 0.90 / 1.05
Manganese 0.95 / 1.25
Silicon 0.45 / 0.75
Chromium 0.90 / 1.20
Nickel 0.25 Max
Molybdenum 0.10 Max
A485-2
Carbon 0.85 / 1.00
Manganese 1.40 / 1.70
Silicon 0.50 / 0.80
Chromium 1.40 / 1.80
Nickel 0.25 Max
Molybdenum 0.10 Max
52100
Carbon0.93 / 1.05
Manganese 0.25 / 0.45
Silicon 0.15 / 0.35
Chromium 1.35 / 1.60
Nickel 0.25 Max
Molybdenum 0.10 Max
- Sections cut out of a ring?
- Flat bar? If so, what size would you like to see it offered in? Stock removal makers would probably like to see a different sized flat bar than a forge maker would like to see.
- Round bar? If so, what size round bar.
A485-1
Carbon 0.90 / 1.05
Silicon 0.45 / 0.75
Nickel 0.25 Max
Molybdenum 0.10 Max
A485-2
Carbon 0.85 / 1.00
Silicon 0.50 / 0.80
Nickel 0.25 Max
Molybdenum 0.10 Max
52100
Carbon0.93 / 1.05
Silicon 0.15 / 0.35
Nickel 0.25 Max
Molybdenum 0.10 Max
