- Jun 29, 1999
I have no real preference as long as they work. Emerson's Nylatron washers work fine, for instance.
Good luck, they are getting rare as hens teeth! Took me minute to find this one and it's a no box "user" though it's near pristine with a super sharp factory edge still.
Geez, you're not kidding. I did a brief search tonight and all I could find was a $600 eBay knife. When did old ZTs suddenly become so expensive?
Dang you didn't hit me up first for the 0620? I guess I see how it isYeah that’s definitely a “I don’t want to sell it” price. I sold my 0620 recently for ~ $250. They’re out there. They were only $200 new.
Given how popular they are, I wouldn’t be surprised if they bring them back at some point.
PB or Teflon, on Hinderers teflon goes really well. With PB I use 10W Nano Oil, on the CRKs I use Krytox 205g0 (high end PTFE), and on Hinderers I smudge a bit of that Krytox as well. Teflon washers don't really need any additional lubrication or benefit from it. They make a really good seal around the pivot and prevent lint from getting in there too. Only downside is they require a bit of finessing to get the action right, once you set them up, they'll compress very slightly after which they'll need a second adjustment, and that's all. Another benefit is ease of replacement, damaged/wore out the washers? They literally sell sheets of the stuff. If you pinch a PB washer or smash it, it's not as easy, and even then, PB/Bearings have zero give and might damage the blade/liners, whereas Teflon will give in way before any metal gets damaged. I believe this is why Hinderer stuck to teflon washers for so long, his XM and Eklipse models also use external stop pins, which reduce the pressure on the pivot greatly, so it takes a LOT of abuse wear 'em out.
Bearings are cool and all, till they get gummed up with lint/debris. They can also dig tra
