Pics? What did you measure them at for a comparison benchmark?
Just dissassembled my Anthem and wow, these bearings are huge. Much larger then the usually (ZT, Hinderer, Koenig). Looking at outer diameter for comparison, what are some knives that have larger then typical bearings?
The only advantage of larger balls is the ability to withstand greater compressive load, which beyond a certain baseline is not relevant to normal applications of folding knives. More important is the diameter of the entire bearing system (the distance of any ball from the center of rotation) and the number of balls.
The balls or the rings they ride in?
@ vanadium What’s the story with roller pin bearings? Do they not have to drag because velocity differance between the bearing end closer to the centre of rotation vs the side on the outside further from the centre.
This is getting deep........but........cone shaped roller bearings would be the perfect solution......with the smaller diameter end of the cone closer to the pivot and the larger end of the cone farthest from pivot......there would have to be milled bearing races to match the angle of the cone roller bearings. This would be the ultimate bearing system......roller bearings covering a large area with no drag
Yes, they have to drag. Shirogorov's "MRRS" system has two concentric sets of roller bearings, which can roll at different rates, partially resolving that drawback. Note the purpose here is not only to increase the number of bearings or contact area, as even the pairs of rollers which could be made as one continuous roller are not:@ vanadium What’s the story with roller pin bearings? Do they not have to drag because velocity differance between the bearing end closer to the centre of rotation vs the side on the outside further from the centre.
I have heard of these legendary cone bearings of the knife gods.
Perhaps some super advanced lost civilization in the past had bearings like these on even 30$ Chinese knives.
Btw Shirogorov multirow bearings are exceptionally smooth seeming to prove more bearings means more points of contact means less resistance means smoother action.
Honestly a huge part of a smooth action is the effect of the detent on the side of the tang. Many bearing knives will drop shut if you hold the lockbar off the tang.
Which is harder to roll forward a foot: A 20ft steel beam laying on two pipes, or one laying on 20 pipes? More contact does not always mean less resistance. But which one will roll smoothly and not dig itself into the soft Earth while holding up one side of your car? Aha.more points of contact means less resistance
I've got one of these working already, just not at room temperature.I'm going to invent the first magnetically suspended blade pivot. Only resistance will be air friction. I just gotta find where I left my flux capacitor so I can get started.
I've got one of these working already, just not at room temperature.![]()
