- Nov 4, 2005
I'm hoping that someone on here can either prove me right or wrong. I recently bought a brand new Becker BK10 and it arrived quickly and all was well. It's a great knife and the size and weight are perfect. However, I did notice that the blade bevels were not symmetrical.
As you probably know,the Beckers have a flat grind,which should end about 10mm from the spine. It's ground correctly (10mm from spine) on the non-stamped side,but,it is ground up to 5mm from the spine on the other side.
I wrote to the retailer and asked if they could see if they had a symmetrical one in stock and they told me that the two BK10's they had in stock were the same as mine. The guy also told me that "the BK10 is a tool to be used in the field and not a collectors item" I said "Yes,I know it's a tool to be used in the field which is why I want one that is symmetrical" then he said "Becker just try to get a good edge on their knives and they don't worry too much about getting the grinds even" (surely thats nonsense
!!) and so it goes on.
Should I expect my £50 BK10 to have symmetrical grind lines or am I expecting too much?
Do any other BK10 owners have this complaint?:grumpy:
Or BK7 owners for that matter.
