Hahah! You sure that's where you posted it? I'm with ya tho man lol.
Heh...well I thought so. I thought I posted it there, copied it and posted it back here. I don't see it over there. With my internet skills, I truly never know.
<snip>
Hope to pick up a 17 at Blade. If all works out, it WILL see a stripping and an attempt at a polish. A bit of hump removal, smooth down the saber grind edge then a patina. It'll be paired with a hawk with a similar finish.
Takes more than a little elbow grease. More like a bucketful. Sometimes it's worth it....sometimes not. On the BK2, I'd say use it like it owes you money. I tend to strip most of my knives, as I feel like the coating sticks to wood and I find my stripped blades are easier to use. And for food prep, IMO it's a must....but that's me. I do NOT polish my knives after stripping....though they don't tend to rust as quickly or easily if you do sand them, even if you can get the grind lines out at about a 600 grit. But it's VERY time consuming, and what you'll likely notice is there are plenty of other imperfections in the blade and it's damned difficult to get everything flat and looking good. I did this once to my BK7 that I modded....and that was a journey, lemme tell ya.
Started like this (after I ground out a complete re-profile):
PIC
......and ended like this after many hours of sanding with an aluminum block and a couple dozen sheets of wet/dry. Too many hours to count, so I didn't. This is up to 2000 grit then Flitzed.....and you can still see scratches! :
PIC
I'm NOT ready to do it again....yet....
Tim, that stripper....WTF? How did it do that?
I've never had that sort of ease of stripping....however I do always use the environmentally citrus stripper, which is bound to be less effective that the real toxic stuff, I guess.
I also like that you couldn't be bothered to clean the last crumbs of that Sara Lee Butter Cake outta the container for your vinegar patina....nice!
if you can't find a 17 at blade, but can find a 16 - I'd be willing to put a clip point on it with or without the swedge. (straight or concave, although straight is easier nd looks better to me)
I like the grind marks. I'm not one for flashy or shiney. Not that I can't appreciate it, its just not for me. I'm like Oscar the Grouch lol. I like stuff old and grungy looking.... The grind marks give a tooled look that makes it look like it wants to be used.
I personally like the contrast of the grind against the"as is" look of the raw steel....
E
I have a 9 that I stripped back in March 2014. Didn't force a patina. Just let it occur naturally. Some patina was initiated by the paint stripper I used. The rest has just "happened" with use. The only time any rust has formed was when I was tired and didn't clean it, just stuck it in the sheath and left it for a couple of days. A very minute amount of rust developed on the edge, no where else. A swipe with some fine grit sand paper and it was gone. If you wipe the crud off of it and spread a very thin coating of oil with a cotton ball, potential rust is a non-problem.
