Speed is probably too fast ,also.
When the buff rubs the polish it abrades the surface and creates a black color. Pressure, speed, and touching any easily oxidized metal ( like silver,nickel, brass,copper) will turn the buff black instantly.Open grained or porous woods are the biggest problem ( using stabilized wood and/or sealing the grain before buffing helps ). Using light passes, taping off the brass guard with blue or green tape ( used by painters and machinists), and avoiding overloading the wheel will help, but some degree of staining is normal.
Use matchless white polish or no-scratch pink. Avoid touching any metal with the buff used for wood handles. Store the handle buff in a zip-lok bag when not in use. After the buffing ,clean the wood off with a citrus based cleaner to remove the excess polish and the stains. Finish that with hand buffing using a soft cotton or flannel cloth.
I want to step in here and make my standard statement.
If you had to ask this question about a buffing problem, you should not be using a buffer, and frankly should not be getting one for a child.
A 14 year old untrained person at a buffer can miss his 15th birthday if things go wrong ( and they go wrong easily).
Buffing is a skill just like driving a car, shooting a gun, or operating a lathe. You don't learn it by "figuring it out as you go". If someone who knows about buffers hasn't taught you...or you haven't read a good deal about it and started slowly and carefully, you can loose a knife at best, a finger easily, and your life possibly.
The buffer is a dangerous tool that looks simple and safe. After all, it is just a motor with a soft wheel or two attached....what possible harm could it do?????
I am sure there will be several posters who can personally attest to the damage possible.
