- Feb 27, 2006
hi, i read here a month ago its a bad idea to use a drill press and crossvise as a milling machine because of safety hazards. i ordered the grizzly G0781. its the second smallest one they make. 177 lbs, 3/4 hp. i have noticed there are different kinds of spindles, this one has an R-8. does that spindle accept the round shank carbide end mills i have been using in the drill press ? if i am going to mill a 1/4" slot for a guard, would it be better to use a 1/4" mill or do two passes with a 1/8" ? i use mostly nickel silver, 3/16". what rpm would you suggest ? thanks for any help. i also ordered a book, "the milling machine for home machinists" by harold hall. hopefully that will answer my future questions.
