- Jun 29, 1999
Diamond hones will work on any steel. I've used a set of DMT bench stones for 15+ years and they still cut as well as when new. Freehand is probably the most versatile sharpening technique.
Wow! That's an awesome gadget there. I'll have to check that out.
How difficult is it to sharpen a cpm154 drop point blade? I've got one on a benchmade mini barrage.
A set of 8" Paper wheels on the HF 6" buffer should run you less than $100 and will do serious work. The only issue is heavy reprofiling jobs.
I found a norton combo stone for cheap and a dmt diamond sharpener for $20 today at Home Depot. Is this the same dmt u guys mentioned? It looks sorta like a butterfly knife design. If that is the right one then I'll pick it up.
Try to make sure its (the Norton) made in Mexico. If still learning and you're already buying the combination stone, I'd hold off on the DMT. Unless you need a pocket sharpener, you'll be better served holding onto your limited resources till you have built up some skills. You'll develop a much better idea of what tools are a good fit. In the meantime, you can do a great deal with that Norton stone.
I don't know, I had stones for years and never really managed to achieve the edges i wanted until i moved to the DMT. In my experience, the DMT was easier to learn good-technique and understand the basics of what sharpening really is - being able to hold both blade and hone with ease and watch as the scratch-pattern formed on the bevel... Also the DMT is easier to maintain, just water or spit and a toothbrush to keep it clean, it's easy to see when it's clogged, and yes it is also light & portable. You can be sharpening your knife while sitting on the John
I'd say get both, but only if the DMT is double-sided (i.e. 2 different grits) and sensible grits. If it is single-sided, wait and just get the Norton.
I have no issues with DMT or diamond plates in general - they do an excellent job. As the OP stated being very low on cash and still wanting to get something that will work well to learn on and do a good basic job, my personal feeling is the combination stone is a much better choice. It has more feedback, grinds just as fast or faster than diamond plates on most steel, cannot be harmed by using too much applied force. If used with oil (cost insignificant), the resulting mud makes an excellent finish/maintenance stropping compound. And it only costs about $6 or $7 bucks. For the money, nothing else comes close. If one has more to spend, all sorts of good options (DMT among them) exist, but that Norton stone will always be useful.
This may sound silly, but it wasn't until i could watch the scratch-pattern forming (i.e. with my face close to the contact point) that i really understood how to sharpen well, how to adjust technique based on the tool and the abrasive being used. I couldn't do that with a benchstone, it was too awkward, so it took longer for me to gain a proper understanding of what i was doing right vs doing wrong in various circumstances. Folks come one here all the time having tried various sharpeners, often high-quality ones, without achieving good results even when a cheap hone could get the job done if they only understood how to use it properly. That's why i keep suggesting the DMTs, especially the folding ones, over benchstones or angle-guide systems - they're not too expensive, they're easy to maintain, you can free-hand with them and do so in a way that allows a different perspective on the process, allowing you to see the effect as it happens with the bevel facing you.
So while the Norton is cheaper, might allow for a decent job (depending on the grit), and may even last longer, I still recommend the DMT if the OP can swing it. It's a good pocket-hone and also a good learning-aid. But that's only my experience.
