- Nov 24, 2005
After thinking about it a bit, a bench grinder does sound appealing, but sharpening on one would void the warranty on a lot of my knives (specifically my Benchmades). So a bench grinder isn't an option (for now).
This might be a good idea. Did it take a while for you to learn how to get to a mirror polish?
Not really, I just set my angle and I don't count strokes. I do count how many times I work the stone from heel to toe and back, then repeat on the other side. Sometimes there'll be a bit of a burr on one side so I'll hit the burred side a a time or two until they both feel even, smooth - what have you. Use light pressure.
When I go to the next stone I will increase the strokes, and repeat the process going through the stones. Keep them rinsed off and wipe them with a rag or paper towel every so often to remove the steel & dirt shavings.
After the xx-fine, you should have an almost mirror edge. I strop with very light pressure umtil I get a mirror edge or very close. I have a .2 micron loaded strop, a 1 micron, and .5 micron, but don't use the last one too often.
Good luck with your choices! :thumbup:
