- Jan 12, 2022
Hello all,
Long time lurker, first-time poster.
As a process improvement engineer in the welding filler metal industry, I keep a close eye on consumables and the long-term costs associated with relatively low-cost items. This really got me thinking as I begin my knife making journey and before designing and fabricating my own belt grinder.
As I have done tons of research in different belt grinder sizes, styles, brands, etc, I decided to take an analytical approach to the consumable cost of the belts. With some simple math using Combat Abrasives Ceramic "Shredder" belt prices in common knife grinder sizes, I broke down the cost of the belts to a $/in^2 basis. Please note, I took out 36 grit, and 60 grit because some of the sizes were sold out at the making of this comparison. So I used 40, 80, and 120 as I think this is comparable to what can be used commonly used for belt progression. Whether you use 36/60/120, or 40/80/120 or any other combination, the numbers seem consistent with the 2x60 being the most economical. Again, this is with Combat Abrasives Shredder Belts.
To break this down further -
Lets take qty. 5 2x72 40 grit belts. This would equate to 720 in^2 of grinding surface. This would cost (5 * $9.29) $46.45.
To use the same 720 in^2 of grinding surface in 2x60, you would need 6 belts (2 * 60 * 6 = 720). This would cost (6 * $6.55) $39.30.
Now we can apply this across the board to get a calculation for lets say 40 grit, 80 grit, and 120 grit, using 5 of each belt.
This equates to a $17.91 savings in only 3 different grits, at 5 belts of each.
Obviously, this is only an example as the amount of belt use on a weekly, monthly, and yearly basis can be drastically different from maker to maker.
I am truly not interested in pinching pennies, I was just surprised at the difference in cost I came up with through a little research and calculations. Over time, these costs can greatly add up which means additions to other areas of the shop.
I am just looking for thoughts and opinions on the above data and the justification over a 2x60 vs 2x72.
Thanks!
Jordan Erickson
| Size | Width (in) | Length (in) | Area (in2) | 40g $/belt | $/in2 | 80g $/belt | $/in2 | 120g $/belt | $/in2 |
| 1x30 | 1 | 30 | 30 | $ 3.25 | $ 0.1083 | $ 2.99 | $ 0.0997 | $ 2.99 | $ 0.0997 |
| 2x42 | 2 | 42 | 84 | $ 4.50 | $ 0.0536 | $ 4.09 | $ 0.0487 | $ 4.00 | $ 0.0476 |
| 2x48 | 2 | 48 | 96 | $ 5.25 | $ 0.0547 | $ 4.50 | $ 0.0469 | $ 4.19 | $ 0.0436 |
| 2x60 | 2 | 60 | 120 | $ 6.55 | $ 0.0546 | $ 5.48 | $ 0.0457 | $ 5.21 | $ 0.0434 |
| 2x72 | 2 | 72 | 144 | $ 9.29 | $ 0.0645 | $ 7.99 | $ 0.0555 | $ 6.99 | $ 0.0485 |
| 2x72 Cost per 5 belts | 2x60 Cost per 6 belts | |
| 40 Grit | 46.45 | 39.30 |
| 80 Grit | 39.95 | 32.88 |
| 120 Grit | 34.95 | 31.26 |
| Total | 121.35 | 103.44 |
Thanks!
Jordan Erickson
