- Oct 17, 2007
This issue seems to come up every couple of years, and more often than not it ends up being the VFD/motor pairing. The noise is called "cogging", and it's typically worse at lower frequencies.
Are you using a KBAC vfd? If so, I suspect your jumper is set for CT (constant torque). Set it to VT (variable torque) just for grins and giggles and see if your noise goes away. Unfortunately, this won't exactly fix your issue, as you'll lose all lower frequency torque, but you will at least have narrowed the problem down to vfd cogging.
