You could if you simply mounted some blocks underneath the tilt stand anchors, right?I have two Reeders in my shop and am happy with them. However the flip feature design must be accommodated with your bench setup. If you are building a new bench or stand it is not a big deal but you cant just toss it on your bench and have both vertical and horizontal options.
Again..... Check out Pheer grinders.I think the AmeriBrade is pretty adamant that they are American. The Alec Steele one is Australian made for some reason, but I think it is coming from Bozeman, Montana. Not sure I understand it. Unfortunate side effect of being a n00b is simply not knowing the names of the famous and infamous companies.They may as well all be Jeaux Bleaux, from Idaheaux
I will look at them again. I guess it would be simpler if I were supplying my own motor/vfd. But I am halfway counting on the supplier knowing more than I do about such things.Again..... Check out Pheer grinders.
I'm Thrilled with mine.
I believe the guy who makes them (Jose Navarro) out of Oregon is a one man shop.
Many knife makers here on BF use them.
I just bought mine for $850 (I supplied my own motor and drive)
he have Tons of packages on his website. More than most....
Its very heavy duty.
So I went back and looked at Pheer. The one thing they don't have is an ability to "flip". There seems like a dizzying number of different options. But pretty much the only difference I see from one to the next is the size of the contact wheel, and motor configuration. Poor guy is stuck using PayPal for his shopping cart, and that makes for a very noisy page. I assume that one could fabricate a mount that would be able to hold it that way, but that is beyond my convenience. They do make a good looking machine though.Again..... Check out Pheer grinders.
No, not really. Even on risers the motor will not clear the bench when horizontal. It really needs a bench that accommodates the design. They sell one for $400. You could also cut a hole in your bench to let the motor pass through. In my case I already had a kmg on my bench and was looking to add another grinder. With the riser installed the working position of the grinder is significantly higher than the other grinder.You could if you simply mounted some blocks underneath the tilt stand anchors, right?
Whichever grinder you go with, make sure it has variable speed.Any strong last opinions before I just flip a coin?![]()
I agree Stacy... While I don't have a grinder by them I do have their surface grinder attachment. I had an issue with their contact wheel on their SGA and Don actually revised their whole process due to that and started precision grinding their wheels in house. Talk about good customer service!!!I'M not trying to push you to a Reeder, but:
Basic Reeder chassis with wheel kit and all the arms/extras - $995
2HP eBay BVFD and motor package fully wired with all the switches - $804
10" Reeder serrated contact wheel (top grade) - $295
$2094 total for a top-grade grinder. Shipping is very reasonable, and the quality of their packaging is unbelievable. Everything comes bolted to a plywood sheet. You could drop it out of an airplane, and it would be fine. Needed assembly and adjustment tools, like Allen wrenches are provided. There is even a place on the grinder to store them, so they are easy to find when needed.
Add the rolling stand for another $395 and you have an uber-grinder setup.
I also recommend the indexable locking handles for an additional $40 (you can get them on Amazon/eBay a bit cheaper if you want. I keep a box of them in the shop for things I adjust often.) These are pro-upgrades and make adjusting so much easier than the provided Allen wrench.
Some other things I didn't mention are:
The double tracking adjustment on the Reeder is amazing. It eliminates most every tracking issue.
The parts are all machined from heavy aluminum. Steel inserts and grade 8 bolts.
Not only is it a functional grinder, but it also looks beautiful. Machine turning, fancy knobs, etc.
Every possible accessory or part you need is available from them. If they don't list it, they will make it. As your skills grow, you can order new accessories (small wheel kits, surface grinders, etc.) and know they will fit perfect.
I've heard amazing things about Northridge and Reeder, but haven't used them myself. I absolutely love my Brodbeck grinder and see no reason to ever need or want a different one! 10/10 would recommend to anyone.
