- Jan 11, 2021
Hi everyone!
This might be a totally stupid question, if so, thanks for stating the obvious
. Im wondering if any of you have tricks in getting the longest life out of your belt grinder belts? I have 3 main grind scenarios: refining out the knife profile, surface grinding (surface grinder attachment) and then bevel grinding. The first two scenarios seem to always damage the belt, in a way that becomes apparent in either the bevel grinding going wonky or subsequent knife surface grinds.
Is there a particular order to which you guys progress through your belts (in terms of age (eg belts used in bevelling and surface grinding are only used x number of times and then demoted to profiling)? Any other tricks? Or should i just suck it up and expect to buy new belts more regularly?
Cheers for the guidance
Amber
Amber
