belt lube or not belt lube
that is the question. i bought a tube of formax F-26 on my last order from trugrit and i thought i knew what it was for. lessen the heat of stock removal, cut down on airborn particles, and extend the life of the belts.
is there ever a time i would NOT want to use the grease? would there ever be a time where using it would be bad?
I haven't used mine often but often enough not to use it on 400 grit belts that will sand wood. Black grease/gunk gets in the wood pores.
