Again, two different types of electricity. in a way
I understand your point but I have also worked with electricity for a long time and what is happening has no relation to the power driving the machine. Static shock from the grinding process will not kill you.
I'm not arguing with you my friend, I clearly understand your points and have seen all kinds of crazy electrical issues myself. But static build up from grinding acts much differently that a electrical issue with the machine and will shock you in different ways. 120 kill you? possible but I can grab 120 lines without being killed.
This issue is common and the arguments that go along with it are common also. The static is from the belt and knife making contact, this postitve charge is looking for a negative path and will find it in either the grinder body or earth ground. You touching the ground causes immediate dissipation of the static charge.
It does not matter if your wearing shoes or not with AC, your getting shocked much harder and you will know the difference.
Again I'm not trying to argue but this topic always gets way off topic with "it could be" and not what is really happening.
