- Jun 8, 2009
I just put together a KMG clone purchased in the supplies section of the forum
"Grinder in a box". I have been using a delta grinder with an 8" multi tool for my grinding in the past.
Anyway, the springs used to apply tension to the belt are a variable I'm not sure of. My belts track perfectly but the belt will wander to one side if I grind heavy on it. This is minimized by extending the tooling arm adding more belt tension. Do I need a heavier spring and is there a way to eastablish the correct amount of tension on the belt?
There are pics of the grinder I put together on page three of that thread, if that helps.
Thank you
Thank you
