Hey Guys,
I got my new KMG up and running yesterday after wrestling with flexible conduit and wire that was most likely a gauge or two oversized... After flipping the switch and rejoicing at the lack smoke or fire I put a belt on and gave it some power. I noticed the belt appeared to be wobbling left and right about a quarter inch. I thought I had something wrong called it a night and returned today to fix it and had no luck. I tried upping the tension, changing belts, changing platens and nothing seemed to take the wobble out. Increasing the tension helped but it was still going back and forth enough to make it impossible to grind anything strait on the edge of the platen.
Everything on the KMG appears to be fine but I don't know how small an imperfection can be and cause this issue. Having changed out the platen and trying two different belts I am assuming the issue lies in either the wheel on the tension arm, the wheel on the drive shaft or these belts. The belts were an amazon discount special, fandeli maybe? Any ideas? Its killing me going to my shop and not grinding a knife out!!!
Thanks!
Thanks!
