beltless carry
ok maybe its a girl thing
but i really do not like wearing a belt.
how do some of you carry yr knives without using a belt?
dont wear boots in summer, dont always carry a bag of any sort...
do wear a neck knife most of the time
pix? thanks
Sounds like an Izula neck carry is the way to go. The factory Izula sheath is a little thick some think, but there are lots of aftermarket options that are very thin.
Yep, it's a girl thing. Only remedy, become a man.
Seriously though. I would recommend a Tec-loc. It's my understanding than you can use them like a waistband clip so no belt necessary. Other than that, I thinkyou'll be limited to either carrying in you bag or using it as a neck knife.
Hat/head band with sheath.....leg/thigh band with sheath .....inside the waist band in back in small of your back....arm band with sheath...bra sheath.... think outside the box:)
I put it in my pocked or have it on a mercharness.
I've sewn paracord loops to the inside of my pockets, so I can put the sheath on a leash (in those pants that don't have belt loops)
They make a Tek-Clip that does that. :)
The only solution imho:
concealable, comfortable and perfect for sunday brunch...
i have whats called "g clips" made from kydex on some of my sheaths.it has a small curved hook that grabs the material of your clothes.i always where sweats so it works out great.spyderco makes them also.i got mine from rainwalker kydex maker.
MerCop had a method where he looped some paracord through a belt loop, and then attached it to the neck carry hole on the sheath and tucked the knife and sheath into his waistband across the front. When he drew the sheath would come out, but as soon as the slack was taken up from the cord the knife would draw. Seems like a good idea and should work without a belt.
i carry in my pocket. i do not carry an izula though. Womans pockets are cut smaller, so it doesn't fit right in my pocket. I carry a bark river mikro canadian and it fits quite nice in there. If I'm wearing my carhart vest I can slip the izula in one of the pockets w/o it being too obvious.
my "purse" is a maxpedition barnicle so there's no fitting anything in there.
