Lately there's been a lot of discussion here and elsewhere regarding belts. Belt value, performance, problems, situations... One thing I can't recall being discussed is which ones are best suited for platen grinding versus contact wheel versus slack grinding. I know it's less of an issue for 2x72 grinders, particularly if you slow things down, but belt "hop" is a hassle with smaller grinders running at high FPM. One of the reasons I use Gator belts a lot on my 2x42 is the lack of any noticeable hop from the joint. Some belts are particularly bad, others are just so so... Some belt lines are specifically mentioned in their documentation as well suited for platen or contact wheel use, others don't say anything at all other than what materials they're for.
I'm just waiting on my 2x72 right now, and ordered a sample of belts to try but figured it's worth asking here as well.
What belts exhibit this hop, which ones don't, which ones do it even on a rubber contact wheel?
I'll start with my experiences in 2x42's since I think these grinders really make things worse with the short belt and high speed.
SY965 Ceramics - Some hop, but not horrid, just don't expect to hold a perfect line
LS309J AO - Same, useable but don't expect perfect holds, a bit more distinct a bounce than the SY965 due to the thinner belt.
CS411X 36 grit - Not a lot of hop noticed, possibly because of the coarse belt as much as anything else. I've never used these in finer grits. This is my 2x42 hogging/profiling belt of choice.
3M Gator Structured Abrasive belts - Best I've found for smoothness. Ironically, I'm not sure 3m's actually making them, I think someone else is making these shorter ones from bulk spools or larger belts. I get mine from Trugrit. 2x42 is not a size 3m lists for this product in their own catalogs.
For slack grinding obviously the 309J's are very soft and flexible, the gators are as well, but tend to bite more at the edge. The SY95 and CS411X are rather stiff and not particularly well suited for it if you want contouring. I haven't used these on a real contact wheel so I can't comment there.
I'm pretty sure I tried some other belts early on and stopped using them because of the belt hop. The ones above are the only ones I have used regularly on my 2x42 in over a year.
Needless to say, I'm excited about the wider options with the 2x72.
