Looking for:
Buck Woodsman Knife, Signature Series, BU-802SS
The illustrated Buck Knife is the Buck Woodsman Knife from the Signature Series that features a 4" clip point blade made of S30V stainless steel, heat treated by Paul Bos. The blade of this Buck Knife has a mirror polished finish and Chuck Buck and CJ Buck signature etch. The Signature Series Buck Woodsman Knife has full tang construction with checkered fancy Walnut scales and lanyard hole. An English Bridle sheath is included with this Buck Knife. The Signature Series Buck Woodsman Knife is limited to 1000 serial numbered pieces. A limited edition box and a certificate of authenticity is included with this Buck knife.
For Trade:
Lightly used Benchmade Snody 210 Activator.
Original Box, Papers and Sheath included.
Never been in the original sheath.
Once you use the Concealex sheath there is no alternative.
The model 210 is the first Benchmade design from Mike Snody, who joins the Benchmade design team in 2004. It is a variation of his "Sportster" model. The Benchmade 210 features an S30V blade, carbon fiber bolsters, and silver G10 scales. Thumb treads along the top of the spine near the handle give this small fixed blade a sure grip. The sheath is black leather, with a black "textured leather" overlay. Included is the optional concealex sheath from Buy Brown Industries. They feature a simulated carbon fiber overlay, lanyard for carry as a neck knife, and a Tek-Lok for multi-position belt carry.
Model 210 specs:
Blade material: S30V stainless hardened to 58-60 HRC
Blade length: 2.5" (6.35cm) thickness: 0.140" (3.56mm)
OAL: 6.50" (16.51cm)
Weight: 2.50oz (70.87gm)
Handle: full tang, carbon fiber bolsters with silver G10 scales
Handle thickness: 0.72" (0.97cm)
Sheath: black leather with black textured leather overlay
Sheath weight: 1.50oz. (42.52gm)
BLUE CLASS (Made in USA)
OR (not and)
Gerber Yari
Been out of its sheath a couple times.
Never cut a thing. Been stored in gun cabinet indoors.
The Yari has a full tang blade made from 154CM stainless steel. This premium blade steel holds an edge longer than other high carbon stainless steels. Heat treated to 59Rc-61Rc, this allows for excellent edge retention, yet maintains great durability. Made with an attractive bead-blast finish, the blades are blackened to produce a non-reflective, durable, black oxide coating. Yari will be available with both fine edge and partially serrated blades.
The handle side plates are made from black canvas micarta. Long used by custom knife makers, this resin/fabric composite is both durable and attractive. Canvas micarta has a warm comfortable feel, and a texture that provides a sure and positive grip. The side plates are attached with blackened stainless steel fasteners. The tang extends beyond the side plates to form the pommel. A hole in the pommel allows for the attachment of a lanyard.
Yari comes with an innovative sheath. Made from Concealex, the sheath is molded and riveted to conform tightly to the shape of the knife. The sheath securely holds the knife without any buttons or straps. For deployment, simply pull the knife from the sheath's friction fit. The sheath includes a belt clip. Designed for multiple carrying options, Yari can be worn inside the waistband, outside on a belt, or securely fastened to a vest or other load bearing equipment.
Yari is backed by a Limited Lifetime Warranty.
Length Weight Materials
Open: 9.625"
Blade: 4.875" 5.40 oz.
- Blackened 154CM stainless steel
Canvas Micarta Handle
Concealex Sheath
For Trade:
Model 210 specs:
OR (not and)
Gerber Yari
Open: 9.625"
Concealex Sheath
