Benchmade 2551S Mini Reflex Automatic - NIB - Black Class - $175 OBO
This knife retails at $220 and I am offering it at $175 via PayPal. This Black Class knife has never been sold, carried or used and is the actual item in the attached photos. It should be noted, the box displays some minor "shelf wear" but the knife itself is perfect. Benchmade has refined the best-selling 2551 Pardue automatic knife, adding increased reliability and an easy access enlarged push button. The 2551S Mini-Reflex maintains the solid performance and toughness you expect. This 2551S Mini-Reflex has a matte satin finished blade with a part-serrated (combo) cutting edge. The black anodized 6061-T6 aluminum handle has a great profile for grip and comfort with a deep index groove and lip at the base. An integrated safety on the handle reduces risk of misfire and the tip-up clip sits right where you need it.
Specifications:
Blade Edge: Combo (Part-Serrated)
Blade Finish/Color: Satin
Blade Style/Shape: Drop-point
Handle Material: 6061-T6 Aluminum (Black)
Designer: Benchmade
Mechanism: Push Button Automatic
Action: Automatic-opening
Blade Length: 3.17" (8.05cm)
Blade Thickness: 0.097" (2.464mm)
Open Length: 7.35" (18.67cm)
Closed Length: 4.17" (10.59cm)
Blade Steel: 154CM (58-61 HRC)
Handle Thickness: 0.48" (12.192mm)
Weight: 2.58oz. (73.14g)
Specifications:
Designer: Benchmade
