Sounds like stop pin not cinched down right, I've run standoffs 25 mil oversize (on purpose) and never had a bladeplay issue.
My take on that is unless you don't know what you're doing and the knife is totally f'd when you send it in, there's no way they can prove it. YMMV
What is 25 mil?
Is that .000025" or 25mm = .98425"?
One is really really small and one is really really big.
Companies can tell, they have high magnification viewers among other tools.
And take a chance of voiding the warranty, because that always helps.....
25 mils is .025 inches.
Hey PaulTR,
I work customer service . r Benchmade. I am sorry to hear that you knife cam back to yo. with the blade play in it. I always go dor the easy fix first, so I think you were on the right track trying to adjust the pivot. Often that will correct it. All of our adjustments on knives sent for service are hand adjusted and often this will corect the kind of side to side play your describing. There is kind of a "sweet spot" where it will not be too tight as to inhibit the motion of the blade and not so loose that it causes the kind of play you are talking about.
I would say that if those basic adjustments are not fixing the play, it should probably come back into us as you may be looking at an internal issue. I understand this is not the popular answer as you just got your knife back, but we can't fix it from there.
If you want to email me back with your Name and Address I can send you a UPS label and we will get that corrected as soon as possible.
The 710 is one of my favorite knives and generally my EDC. I am sure that once we get everything doing what it should be on there that you will develope a similarly colse relationship with yours.
Benchmade Knife Company
Customer Service
Nolan C. Kidwell
800-800-7427
nkidwell@benchmade.com
Hey PaulTR,
I work customer service for Benchmade. I am sorry to hear that you knife cam back to you with the blade play in it. I always go dor the easy fix first, so I think you were on the right track trying to adjust the pivot. Often that will correct it. All of our adjustments on knives sent for service are hand adjusted and often this will corect the kind of side to side play your describing. There is kind of a "sweet spot" where it will not be too tight as to inhibit the motion of the blade and not so loose that it causes the kind of play you are talking about.
Customer Service
Nolan C. Kidwell
800-800-7427
